Old 18-07-2007, 08:01 PM   #1
dash007
dash007's Avatar
Default need help please :-)
Gday all
I have a problem with my 1987 KE Laser.
The problem is I have a whining noise coming from the front, at first I thought it was the bearings replaced them noise still there. So had a good look under car and noticed that the drivers side CV boot is split in two , could that be making my noise ?
And the other thing is where is the filling point for the gearbox ?
Any response would be great.
Cheers Dash007
dash007 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 06:29 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
you would be best to buy a reconditioned CV drive shaft for that drivers side to be sure
gearbox is a guess the speedo is used as a dipstick and filling point on some small manual gearboxes but wait for a laser guru
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 05:15 PM   #3
hitork
Injected
hitork's Avatar
If the boot is cracked it will have filled with dirt and crap and will almost deffinatly be the source of your problems. I know on the av telstar the fill poin and dipstick on the manual is the speedo cable opening. It is at the rear of the box.
I recently had my LHS driveshaft replaced with a reconditioned on as that is the best option. If you live in Melbourne PM me and I can give you some advice on places that I have had good experiances with.
Good luck.
hitork is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2007, 10:11 AM   #4
dash007
dash007's Avatar
Thanks guys. I have now replaced the driveshaft and replaced the gearbox oil (there was auto trans fluid in it from the previous owner!) but the noise is still there and getting worse.
I did replace the driveshaft on the passenger side a couple of months ago. Is there any part of that that could be making the noise? I am running out of ideas!
Old 20-07-2007, 05:26 PM   #5
dirty hands
Over Thinker
only the clutch release bearing or gearbox bearings
then there is diff whine how many kms are talking about here ?
some ford manual gearboxes do use automatic oil what does the service book say or label under the bonnet
ATF or hypoid 90 ?
Old 20-07-2007, 06:19 PM   #6
coombesplo
Tell the missus to get out and you will probably find the whine disappears. You did say any response would be great!
coombesplo is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2007, 10:28 PM   #7
dash007
dash007's Avatar
HA HA HA HA
If it is the gearbox/diff how hard are they to pull out put in ? To replace
The car has done 340,000
Old 21-07-2007, 01:28 AM   #8
dirty hands
Over Thinker
Question
well gearbox comes out from underneath
with car stands floor jack
the drive shafts out /the right tools
starter motor
box out
probably 2 hours if not touching the clutch
fixing that gearbox gets complicated unknown to me
have to wait for a laser guru :
Old 21-07-2007, 05:32 PM   #9
dash007
dash007's Avatar
OK the only thing it can be is the box I think.
Where would be the best place to get one ? Have a wrecker that will give me a change over for $275 is that a good price ?
I am in Berwick Vic
Cheers Dash
Old 21-07-2007, 09:06 PM   #10
dirty hands
Over Thinker
get a second opinion about the box condition
any mechanical workshop or gearbox shop will do
if the noise is there and they also confirm that the box requires overhaul
then that price is fair and even better if it comes with a warrenty
Old 22-07-2007, 09:24 AM   #11
dash007
dash007's Avatar
Will do, thank's for the reply's
Cheers Dash
Old 24-07-2007, 06:18 PM   #12
hitork
Injected
hitork's Avatar
You are now at the stage where specialty tools and a wealth of automotive knowladge are required, I would not attempt to fix it myself at this stage if i were you because when you do screw up it is a long and expensice tow to the mechanic. I recently had a new 5 speed manual put in my AV TX5, finding a seccond hand box can be a challange because those manual boxes usualy last for eaver if treated right so there is a low demand for them. I got a box that had done something like 40,000 kms fitted for something like $900 but dont quote me on that because i cant remember and there were also other repairs done at the time.
Good luck.
Old 01-08-2007, 10:14 PM   #13
mk2-71GTL
I Have A Maza 626 Doing The Same Thing And Its A Front Wheelbearing Making The Whining Noise So Get Both Bearings Checked B4 You Tackle The Gearbox
mk2-71GTL is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2007, 10:52 PM   #14
dash007
dash007's Avatar
Well got the LH bearings replaced with new one's today and problems gone. no more farking noise :
Cheers Dash
Old 02-08-2007, 10:55 PM   #15
dirty hands
Over Thinker
well done ...mk2-71GTL... : .
good to see how forum imput can differnt advice
and help someone fix a car
and not have the cars owner get ripped off ....
