View Poll Results: How often do you get your AU serviced | |||
Major/minor (50k, 10k) servicing only | 57 | 41.01% | |
Service more often that recommended servicing | 66 | 47.48% | |
Service it occassionally (no fixed timing/kilometers) | 10 | 7.19% | |
Hardly ever | 6 | 4.32% | |
Voters: 139. You may not vote on this poll |
14-08-2007, 06:45 PM | #61 | |||
Sly like a G6
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
14-08-2007, 09:53 PM | #62 | ||
Spin 'em Habib !
Valvoline Oils Are Crap .. So are there Filters and So are there Trans and Manual Oils ..
Castrol Edge Gold Sport is the GO , you get what you pay for .. Alternatively , there is Penrite Semi-Synth , Which is awesome and reduces Fords Ticking ability .. Ford AU Cooling System is 16.2 Litres , which Means you will need 2 Bottles of Concentrate , dont use Premixed AU BTR Transmissions use 18Ltrs to Flush and a Further 8 To Refill and Top Up Using ATF Fluid ( Dexron III i think ) Changing my Brakes this Weekend .. Bendix Ultimate Ceramics and RDA Slotted Cross drilled Rotors .. Along with a Full Pureone Filter , Castrol Edge Oil Change , K&N Filter Swapped to a New FRAM Racing Pod Setup , Bring on Racing at Calder on Friday :
AU2PWR |
15-08-2007, 01:00 AM | #63 | |||
Sly like a G6
04-09-2007, 02:50 PM | #64 | ||
Mr Polish
Well it hasn't had a service for over a year but it never goes far and will only go interstate by being in the top deck of our supercar transporter.
We have a hoist for the race cars so I borrow that and change oil every 7K, change ign leads every 40K (got eagle golds on their now which has improved starting) change plugs every 40K and diff oil is redline heavy shockproof so 100,000 easy before I change that again. Coolant gets done every year and I clean out the bottle at the same time. Thats pretty much due now as is brake fluid (once a year) and checking of brakes and bushes/gearbox
Detailology colour fx detail studio and R&D Lab SA's leader in auto detailing and paint treatments |
04-09-2007, 06:34 PM | #65 | ||
Finished my AU's "big birthday service" a couple of weekends ago.Replaced the 5w/30 with 10w/30 Valvoline and have done a long trip up north and day to day running since.No lifter noise-and I'm sitting on 255,000kms- so I wouldn't be too quick to discredit Valvoline oil.
Flushed the coolant and replaced. New plugs. Cleaned the throttle body and replaced the filters.Used a Fram air hog this time to compare to the K&N and I am impressed. Took all my wheels off and cleaned my brakes and rotors. Added some conditioner to my battery. Changed my diff oil. Only recently had my auto done,so I really only have my brake fluid to flush through and replace and she is good for the summer! |
