My AU XR8 is due for its 100,000km service. When I bought it, the owner's manual was not in the car, and the guy I bought it from said he purchased the car without it, so couldn't help. Basically, I need to know what I have to do in this service. I do have an auto repair manual but it doesn't specify give specifics. thank you
#2 | |||
Blown 5L coming
did my 100,000 service on my forte a couple of months ago (just did 110,000 service today) service includes:
*Brake fluid flush *Coolant flush *Replace fuel filter *Replace oil filter *Replace air filter *Replace engine oil *check condition of diff and transmission oils, replace if neccessary *rotate tyres front to rear *check operation of all lights and wipers, replace if neccessary *replace spark plugs and leads if neccessary *check condition of all moving components such as ball joints, wheel bearings, seals etc i.e. no excessive movement, leaks etc *lubrication of door, boot and bonnet hinges and locks including check plates (use dry lube on check plates lithium grease on the rest) silicon spray or graphite powder in power window guides and then just a general check over of everything to make sure everything is tight and clean....no leaks ![]() hope this helps
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
For an AU1 XR8
Oil, oil filter, air filter, fuel filter, plugs and a full check over |
Thank you all that will help just got to get all the parts now
