Old 05-11-2007, 08:06 PM   #1
4dlvr
4dlvr
Default lr zetec gear knob
how do i go about changing a lr zetecs gear knob, i thought ill ask before doing it myself. its looks like a bit of a challange because of the thing you have to push up before selecting reverse gear.
are their special gear knobs i have to buy or can any one be fitted on,
and last of all how the hell does the standard one come off???
thanks in advance
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 08:40 PM   #2
photn
AFF Post NAZI
photn's Avatar
hey mate.
they pretty much are special gear knobs as far as iknow.
im just going to stick with the Optional Ford one.
Old 05-11-2007, 10:22 PM   #3
melbzetec
Old enough to know better
melbzetec's Avatar
You need a gear knob for "reverse lift". there are a number around.
The knob just twists off
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2007, 10:45 PM   #4
FOCUSonTHIS
FOCUSonTHIS's Avatar
screw it anti-clockwise to take it off and clockwise to screw it on. Simple as that
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
FOCUSonTHIS is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2007, 01:16 AM   #5
4dlvr
4dlvr
oh beatttyyy, in that case i should have one in a few days time, ill post pics when i do
cheers guyz, thanks for the help
96 EF FAIRMONT
215rwkw @7psi
