Old 30-05-2005, 06:05 PM   #1
Paris Hilton
Custom User Title
Paris Hilton's Avatar
Default Roadworthy
I have a 1989 EA S-pac and it has to go in for aroadworthy cirtificate before I can change the rego over. It is an ultra rare 3.9 that DOESN'T leak oil :P, doesn't blow too much smoke etc, tyres are 3 moths old, it is all good. However, the rear right hand passenger seat belt doesn't retract. It pull out fine, but just won't go back in. Will this be a cause for my car to fail a roadworthy inspection?
Paris Hilton is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2005, 06:11 PM   #2
Psycho Chicken
Psycho Chicken's Avatar
It would in Victoria.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2005, 06:14 PM   #3
Damo
try fixing it ?
Or Just pull it through from behind. I doubt they're gunna test your rear seatbelts.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2005, 06:22 PM   #4
Thornie
Off smelting
Thornie's Avatar
Originally Posted by Damo
try fixing it ?
they would most proberly fail your seatbelt for not retracting, even having frayed edges like one of the cars i had an inspection done on depends who you take it to i guess the rear shockers are absolutly nackered in my charade but it still passed a roadworthy they they were going to fail it because the rear numberplate light globes were blown.
Thornie is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2005, 06:25 PM   #5
Psycho Chicken
Damo, in Vic you have to test that all seat belts draw, retract, don't have frayed edges, lock when pulled and are firm in the buckle. Rear belts included.
I'm guessing the ACT will be the same.
Old 30-05-2005, 06:38 PM   #6
Damo
ahh fair enough. My mums old Galant passed a recent roadworthy, and the seatbelts in that were pretty dodgey, ciggy burns, frayed, and the middle one was difficult to plug in.
Just fix it Selekta, can't be that hard.
Old 30-05-2005, 06:58 PM   #7
Psycho Chicken
Yeah, just go grab one from a wreckers. But make sure you check it before you get it, you can't pull them out unless they are mounted in the car.
Old 30-05-2005, 07:09 PM   #8
rag top
rag top's Avatar
I'd get the inspection done; If they pick it up, get it fixed ASAP; if they dont, fix it at your lesiure. A number of ACT inspectors are not that thorough...
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
Old 30-05-2005, 07:36 PM   #9
FNQracing
RAGE Engineering
FNQracing's Avatar
Short answer, yes, it is a roadworthy item. Anything wrong with any of your seatbelts you'll fail. However, many don't even bother to look. Get it roadworthied, and if they pick it up, I'd fix it then.
If it doesn't fit, use a BIGGER hammer
FNQracing is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2005, 09:25 PM   #10
Paris Hilton
Custom User Title
Seatbelt is fixed. It's one thing after another. *sigh*
When the car stops, it drops about 200ml's of coolant...no more, no less...will this be a cause for concern?
Old 01-06-2005, 09:31 PM   #11
smciner1
Detroit Locker Equiped TM
smciner1's Avatar
Where is the coolant coming from? Engine? Radiator?
Apollo Blue 1974 XB Falcon GT, 557 HP
Blue Pearl 2004 BA FPV GT, 290 kW
Originally Posted by MRJUCY
Simple give the car a rev & have a listen a Windsor makes a sort of wheezy drone similar to an angry Hugh Grant when a Clevo will sound like Satan has woke up with a hangover & realized he is out of coffee & cigarettes
Falcon GT Club of Geelong.
http://www.facebook.com/FalconGTClubGeelong
smciner1 is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2005, 10:13 PM   #12
Paris Hilton
Custom User Title
Radiator.
Old 02-06-2005, 07:30 PM   #13
rag top
rag top's Avatar
What if you don't top it up?
Does it still drop the 200ml on the next trip??
Current Rides:
