17-11-2007, 11:28 AM | #1 | ||
Hi.
Went to Ultra Tune yesterday and they have given me a list of things that needed to be fixed costing around $1000, so i thought I'd knock some of the stuff on the list myself. I've got a couple of questions and would greatly appreciate any help. 1. What type and brand of brake pads should i be looking for. I need them just for normal driving and don't want a lot of dust. I've heard the Bendix Ultimates are harsh on the discs. While changing the pads i also want to flush the brake fluid. How do i go about doing this properly, and how much brake fluid will i need to buy. 2. What coolant should i use and how much does the falcon take. Also how can i do a full flush of the system so that i can get most of it out. I've read another thread where someone has only been able to get 5L out. Thanks for all your help. |
18-11-2007, 12:10 AM | #2 | ||
not here much anymore
Bendix Ultimates are damned good pads but you are right they will chew through a set of rotors in no time. Id probably go Bendix Advance or GCT, I have Advance on the ute now (mine are not stock brakes though), and wouldnt mind moving up to the GCTs as I am not kind to my brakes. Set of GCT's for the front should cost you no more than $60.
Coolant - go for a concentrate and mix it yourself, to flush just keep it going until all the coolant comes out and youre only getting clean water. From memory the 6cyl system holds 8 litres but I can check that @ work tomorrow.
RAM 1500
18-11-2007, 02:56 AM | #3 | ||
_Oo===oO_
1. I'm currently running Bendix GCT's. Works well from cold, no squeaks, no noises, a little bit of dust, not excessively so, but doesn't chew out rotors. Brake fluid - 0.5 litres of DOT 4.
2. Coolant refill capacity is actually 16 litres for the sixes.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
