Old 15-01-2008, 10:23 PM   #1
RJO89
EuroFordClub
RJO89's Avatar
Default New rims for my Focus =D
Hey guys,
Just a quick question. I'm looking at getting new rims for my 07 CL focus (the hubcaps just don't do it for me!), and I just wanted to make sure that 17x7's will fit the car with no worries, with tires that'll probably be 225/45R17. That's not gonna have an effect on the speedo or anything is it?
RJO89 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2008, 10:50 PM   #2
pertuan
Focus on my Focus
as long as the circumference of the tyres is the same as the stock wheels, the speedo will be ok.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2008, 09:22 AM   #3
twistedfirey
There are a few tyre size calculators around like this..
http://www.euroshina.com.ua/calc.php...5&dn=17&lng=en
twistedfirey is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2008, 09:24 AM   #4
twistedfirey
oops try this.
Old 23-01-2008, 01:19 PM   #5
trenchtractor
717rwkw per tonne
trenchtractor's Avatar
Stock tyre sizes off the plackard are as follows:
195/65R15
205/55R16
205/50R17
I'm not sure why you'd put 225's on a 7" rim, it might look 'cool', but you'll find the tread surface will distort during cornering causing poor performance and premature wear.
You should always try and fit a tread width that is the same as the rim width to prevent distortion. You'll have better wear, better cornering performance and your tyres will be cheaper.
I can't think of an easy way to describe it, so I drew a picture, and the scanner's not working so I took a photo!
Brad
TT rides a yellow 2006 Yamaha FZ1N
Who is trenchtractor?
See my YouTube
See my BikePics
Jane drives a 2006 Ford BF MKI Falcon
trenchtractor is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2008, 01:41 PM   #6
trenchtractor
717rwkw per tonne
Here's a quick breakdown on tyre measurements...
205/55R16
205 = width of tyre in mm through the 'belly' (the bulge halfway between the bead and tread). NOT the width of the tread. Example, Jane's 195's have a tread width of only 170mm. It's the fattest part that 195mm.
55 = Profile, as a percentage of the width measurement (in this case 55% of 205mm). Measured from the bead, not the rim.
R = radial construction, as opposed to that old conventional construction.
16 = rim size measured in inches.
Load index = Load rating for each tyre. Ranges from 81 - 96, which equates to 462 - 710 kg/tyre respectively.
Speed = Speed rating. Ranges from N - Y, which equates to 140 - 300kph. Common speed rating for performance tyres is Z.
A point on the measurements... each manufacturer seems to take a slightly different interpretation on the measurements. That is to say a 205/55R16 is not always a 205/55R16.
But don't take my word for it, Tyrepower has a description of how to read it.
Brad
See my YouTube
See my BikePics
Old 25-01-2008, 11:46 AM   #7
GSR
Focus LT
GSR's Avatar
What are you going to do with youre old hubcaps?, Im looking for a set.....
Originally Posted by edgecrusher89
Hey guys,
GSR is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2008, 06:29 PM   #8
RJO89
EuroFordClub
RJO89's Avatar
Gonna keep them for when I sell the car, so that I can keep the rims. Sorry mate
Old 25-01-2008, 11:42 PM   #9
GSR
Focus LT
GSR's Avatar
No worries, I thought that might be the case, but just thought to ask.
