i recently bought a 1989 laser KE GL and i have been having over heating problems i got the RAC to have a look but the guy said it was just a small leak in one of my heater hoses i have a feeling it is something more than a small leak as i am filling the radiator up every time before i start the car and it overheats within 10 minutes of driving when i pull over the water in the resevoir is normally bubbling and i can hear air escaping from somewhere but there is still some water visible in the radiator is there any other reason my car is overheating so much?
Over Thinker
new radiator cap
check thermostat is not sticking shut ... take off the housing drop it in a saucepan of boiling water make sure it opens check radiator fan is working plus the thermo switch at worst head gasket needs replacing look out for water in the sump oil clogged radiator or not eneough cores clear for water flow is water pump in good condition
My car goes Brumm Brumm |
