22-04-2008, 04:03 PM | #1 | ||
[ON DUBS]
Can anybody tell me,
are there any differences between the EF/EL I6 intake manifold and the AU's? Thanks.
BA MK2 XR6T |
22-04-2008, 04:12 PM | #2 | ||
Teh Baest
I'm pretty sure EF-AU was the same multi path manifold
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
22-04-2008, 08:14 PM | #3 | ||
Are you sure about that?
AU Series has the TMAP sensor in the manifold wher the EF/EL has a MAP Sensor on the firewall.
AU Series 1 has a two bolt sensor and Series 2 and 3 has a two bolt sensor. The Series one will throw a MAP sensor code alot easier than the Series 2 and they are not interchangable
When I grow up, I want to be half as good as you THINK you are. |
22-04-2008, 08:26 PM | #4 | ||
Sly like a G6
The top half of the AU S1 manifold has a "WR2A" prefixed part number, meaning it's a part introduced with AU1. If it were the same as the EF or EL it would have a part number prefix of "EF", "94DA", "EL" or something like "96DA".
The AU2/3 manifold's top half has a "1R23" prefix (for first usage on AU2) as suggested by TechTrainer's post above.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
