26-04-2008, 12:09 AM | #1 | ||
Hey guys I need to get to the cam chain tensioner to fix an oil leak. the last ford i had was an EA (hence its been a while) although I also have a BAXR6 I brought in Nov 07, which has been a great car, however I can't figure out how to remove the fan belt....the EA had a tensioner pully you could loosen to get it off....can anyone help?
26-04-2008, 12:10 AM | #2 | ||
Sorry everyone its not the BA I am trying to fix its an AU ute
26-04-2008, 12:18 AM | #3 | ||
yeah the au has a tensioner pully that you put a rachet on and pull on, it is spring loaded, if you push on the belt you'll see it move and see which way to move it to get the belt loose
26-04-2008, 12:22 AM | #4 | ||
yeah i thought so. there is no hexhead on it though? are you talking of a special ratchet?
26-04-2008, 12:25 AM | #5 | ||
tufLTD
It's not a hex head, it's a 3/8" square, just use a 3/8 ratchet.
26-04-2008, 01:46 AM | #6 | ||
Sly like a G6
If you're fairly strong you can lift the belt off one of the smooth-side pulleys with your hands then slide it off. This gives enough slack to remove it from the other pulleys. I usually take the thermo fans out first to give some room. I used to be able to put the belt back the same way but since I put a new belt on at around 300,000km I've had to use the ratchet handle. The new belt's my excuse anyway... soon I'll have gold chains, a convertible and a busty blonde LOL.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
26-04-2008, 03:00 AM | #7 | ||
hehe if gold chains gets me a busty blonde im in.
