Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 02-01-2009, 01:09 PM   #1
BENXR6T
BENXR6T's Avatar
Default taking the pursuit racing
hey chris & the team
hope you guys had a merry christmas and happy new year
chris, after my accident in the pursuit and the well body being buggered, i'm building a custom alloy checkerplate tray with big tubs to fit some decent MT's under there
what i want some advice on is which route i should take with the ute, what to do with the motor and driveline. i want to race the ute in ANDRA super street meetings at the motorplex.
i'm hoping to achieve times between 11.8 - 12.3
i really would like to stay NA, as ive always has a thing for a tough NA BOSS 290.
would a cam, full exhaust, oil pump gears, underdrives, 4.11's, my BPR CAI, a stall ( wanting to sell my 6 speed box and put a 4 spd auto in ) and some decent MT's see me around my aim? i reckon it wouldnt be too far off.
also, for being competitive, do you think its a good idea to chuck the 4 speed auto with a stall in? i want to be as consistant as possible
thanks in advance,
ben
05 BA II Pursuit Ute # 147 in RAPID
20" incubus rims
6 speed manual
BLUEPOWER CAI
twin 2.5" catback
more to come
BENXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2009, 01:46 PM   #2
AUSGTI
Das Auto Bitches!
AUSGTI's Avatar
ill swap you my 4speed for your 6speed
MY14 MK7 VW Golf GTI - waghoon!
AUSGTI is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2009, 02:08 PM   #3
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
Wish i had a 4 Speeder to swap.. want a T56 conversion bad..
Have fun Racing the Pursuit mate, im sure with the Combo you have mentioned you will get the times your after.
FPV8U is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2009, 05:17 PM   #4
BENXR6T
BENXR6T's Avatar
i'd be interested in a swap plus cash difference...there are so many people after the 6 speed box.....
anyone reccomend what cams i should be using, or looking at?
20" incubus rims
6 speed manual
BLUEPOWER CAI
twin 2.5" catback
more to come
Old 02-01-2009, 05:23 PM   #5
FPV8U
FPV8U's Avatar
I'd talk to chris but probably a Crow GTPX Camshaft set.
Old 03-01-2009, 11:21 AM   #6
JAZZA315
Im sure Chris would reccomend one of his own/custom grinds before an off the shelf item.
JAZZA315 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2009, 09:49 PM   #7
CAMS290
trying to get a leg over
CAMS290's Avatar
I ran 11.80's with standard cams and standard cam timing with my auto Pursuit.
All the usual bolt ons, full slicks too.
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2009, 12:13 AM   #8
BENXR6T
BENXR6T's Avatar
how much would i be looking at to change to a auto? the install? if i sold my 6 speed manual, then bought the auto, how much would i be looking at for the changeover?
20" incubus rims
6 speed manual
BLUEPOWER CAI
twin 2.5" catback
more to come
Old 05-01-2009, 09:28 AM   #9
Bluepower
KenneBell Australia
Bluepower's Avatar
Hi Ben, hope you have been well.
I have found the 11 sec bracket to be a bit "too easy" with a stock unopened 290 auto - our only ever outing in race trim saw an 11.76 on an uncracked 290, even giving the rpm limiter a fair nudge...........
The REAL issue here is, what state do you want to leave your car in?????
are you wanting to leave your car in standard format, i.e GT brakes, stock suspension? if so thereby having like a 3000rpm converter which will be "much" nicer on the road??
OR
are you prepared to do a bit of "prep" - remove the pass seat, tailgate, part exhaust and run a bigger converter that wont be quite as user friendly on the road??
The first option with a good drag radial will see you within your 12.3, but i would guestimate that would be about "all it would have".
Upping the ante would see an 11.7 as a minumum, perhaps faster, but its up to you whether or not you can stand the pain of playing with the car so much.
Cams in the Boss will see you with maybe a tenth, probably not worth it unless a full twin TB setup as well to maximise everything.
Feel free to drop me a line to discuss if necessary.
Chris
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2009, 11:59 PM   #10
BENXR6T
BENXR6T's Avatar
im prepared to remove tailgate, passenger seat out, part exhaust.....i will be selling my PBR brakes too so i can chuck on a full set of weld drag rims too.
is it worth changing over to the auto? ive heard it a pretty big job, and pricey too, changing pedal box, computer etc? i think i may be better off whacking a tex clutch in along with a ripshifter, and seeing how consistant i can get.
20" incubus rims
6 speed manual
BLUEPOWER CAI
twin 2.5" catback
more to come
Old 07-01-2009, 12:43 PM   #11
Bluepower
KenneBell Australia
Bluepower's Avatar
id certainly try the manual first, Craig managed to run an 11.94 in the GT sedan, which would make maybe in a ute that can be launched a little harder an 11.8 maybe??
Yes, an auto conversion is a real ****er, best avoided coct wise.
Chris
Old 08-01-2009, 05:01 PM   #12
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
With the manual Ben you have to be prepared for alot more wear and tear on your car compared to running a auto, breakages will happen also look strengthening the rest of your driveline which will limit breakages to a minimum, launching a manual hard is real harsh but alot of fun when you start getting into the 1.7-1.6 60ft's.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
