xr8 ute
does any one know if you can change the amp in a fairmont ghia to a higher powered one i have a au f g 111 with sat nav 5.0 lt thanks.
u cant
the standard headunit doesnt have RCAs poking out the back but has RCAs going INTO teh stock amp.. the RCAs will produce NO noise from an aftermarket amp..(tried that) you wil need your self a new headunit .. and all the wiring required to put a new amp in...(RCAs..power.. ground..remote cable) then yeah.. if you disconnect the standard amp.. the standard sub and both standard rears will stop working even when connected to the aftermarket headunit.. its wierd.. hope i helped |
xr8 ute
ok thanks ill stick with what ive got,.,.,.,.//.,
acttually you can i have done it in mine and the whole idea was to keep my factory HU cos i like the 6 disc in dash feature.
AU III Fairmont Ghia All you need is a little thing called a Stinger line level converter and the new amp thats it. And make sure to buy the stinger ones they are the best and i have three in my car. |
I would presume you could also use an amp that has speaker level input if you dont want to spend too much.
Cheers, Phil |
Not sure as i bought Kicker amps and tried using the speaker hi level input plugs it had and the signal of the stock system did not match so therefore it had to be line level converters. here is the thread we had on it: http://www.fordforums.com.au/showthread.php?t=2677
Smile
Dont muck around mate.You can get rca adapters which get connected toexisting speaker wires and convert to low level rca comaptible sound.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
Yeah that's what we are talking about they are called Line Level converters and the good ones boost the signal to give a clearer sound as an aftermarket HU would.
Smile
Thats great if they do that..but depends on thd(total harmonic distortion.) of the components really.
