24-03-2009, 11:18 AM | #1 | ||
Giddy up!
I've used these before in rural Victoria, and I find them to be difficult.
Unless I am going something wrong these pumps, they constantly clicks, I have to use the adapter thing that was in with spare, and I can't put it all the way in with out the adapter on (lucky I'm not childish, or else that could have been rude!). I got a message through on the UK forum, that all you do with the normal diesel pump is simply put it in, rest it on the edge and fill. This works a treat, but can't do it with the high flows, as the adapter is required, and I have to have it out a bit to allow for the fuel to flow in, so it's not in hard against the adapter.
Current: June 11 built Titanium TDCi Territory, Edge, side steps, mud spats, bonnet protector, tow pack, full tint. Nov 10 built XR6 Sensation. Previous: Oct 07 built Mondeo TDCi hatch, Stardust Silver, bluetooth, leather, tow pack, sunroof. |
24-03-2009, 01:49 PM | #2 | ||
Is there supposed to be a question in that paragraph above?
Most servo's have both, use the small bore 'normal' one for your car. The larger high-flow ones are there for the trucks, some of which can carry over 1000litres of fuel which would take a while on a small nozzle. If there is only a high-flow one available then you are doing the right thing using the adaptor, but you may have to try and only pull the trigger a tiny bit at a time to slow the flow rate down otherwise it will click off to stop fuel leaking all over the side of the car. If I missed the question and ansered a different one, sorry!
July 2008 build Sea Grey TDCi Hatch De-badged with number plate WIFEY'S Wifey want's to know how many times someone is going to ask her if she knows she has pulled up at the diesel pump? |
24-03-2009, 05:34 PM | #3 | ||
Giddy up!
Thanks for the reply Shiner.
I am sorry I didn't put a question mark and a question in. Looks like you've had the same issue with haveing to leave the pump out a bit on the high flows. That's what I have to to. Sometimes I find that there are no cars/trucks at the high flows, but more at the normal pumps. You're lucky that your wife wants to fill it up - she wanted to once, picked the pump up, got diesel on her hands, gave it to me and said it's my job!
