got a laser here with a bad clutch (no clutch) , it has been slowly getting closer to the floor and now there is nothing, its a fluid issue the clutch itself is fine.
ive tried bleeding the clutch system but i don't seem to be getting any pressure down at the slave cylinder. my question is what is the name of the doohickey on the firewall that the clutch pedal pushes on via the connecting rod? i assume that's where the pressure comes from. whatever its called is it serviceable ie: kits are available or is it a throw away and grab a new one item. GH |
i believe you are talking about the master cylinder? yes, there should be rebuild kits available for them. i would also get a kit for the slave cylinder too, and do them both at the same time, at least that way you will have all new seals and fluid in the clutch system
