Old 28-09-2009, 06:32 PM   #1
Ibrox90
Ibrox90's Avatar
Default Ford decal....sticker....thingy
Ok so for the Xr8 i swas thinking of getting the word "Ford" on the top of the windscreen......
except I have no idea what its called......
Are these sticker commerically available or is it a custom job???
HIS
THUNDER
2004 BA XR8
Blueprint
Mods:
Quad Exhaust, Hi-Flow Air filter, BFtiming chain tensioners, Billet Oil pump gears
stage 2 shift kit, riding on G6ET 18's
HERS
FLASH
BA MKII XR6 Turbo
Phantom Purple
Typhoon front end
Parking your ford after a long day of being Awesome
http://www.facebook.com/pages/Parkin...37774932974038
Ibrox90 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2009, 06:35 PM   #2
Jack91
Jack91's Avatar
On ebay all the time:
http://cgi.ebay.com.au/FORD-Windscre...d=p3286.c0.m14
Just remember when sticking them down to spray some water down first then lay the sticker down or else it will never be straight
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2009, 06:41 PM   #3
Ibrox90
Ibrox90's Avatar
spray some water down?
HIS
THUNDER
2004 BA XR8
Blueprint
Mods:
HERS
FLASH
BA MKII XR6 Turbo
Phantom Purple
Typhoon front end
Old 28-09-2009, 07:10 PM   #4
Lightning Strike XR6
Lightning Strike XR6's Avatar
Yes on the glass. Also helps get air bubbles out
www.bseries.com.au/04xr6
Buying or Selling property in Melbourne PM me!
Lightning Strike XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2009, 07:30 PM   #5
Jack91
Jack91's Avatar
Yeah, before you put it on, mix 1 drop of detergent (no more than that) with water in a 600ml sprayer bottle spray it all on the glass where you want to put the sticker, lay the sticker on the water, get it in the right position, then use a credit card and push it all down with that and the water should come out with it, means you can move it around before you stick it to get it right and you dont get any air bubbles as said.
edit: detergent is optional, but I was told about detergent from a signwriter so I guess theyd know. It will stick just as good if not better than it would've if you hadnt of used water.
Old 28-09-2009, 08:19 PM   #6
XKool
XKool's Avatar
As Davo said... But ditch the detergent, just use plain water and don't be scared of putting a bit on, you can spray the adhesive side of the decal as well. I am a Signwriter and if you use detergent then it takes to long for the water to dry out and it just takes forever to adhere to the glass, also apply it in the shade and when your all done just park it outside in the sun for a bit to dry the water out.
D.
XKool is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2009, 03:17 PM   #7
distortion
D.
I second this - graphic designer at signwriting company here - make sure windscreen is CLEAN!!! use water then metho to clean and make sure its super dust free... a little metho in the water helps lubricate the decal to re-position. use masking tape half way through width of decal to get in position, fold one half back horizontally, remove backing paper, and cut it off, then apply
distortion is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2009, 08:07 PM   #8
buggerlugs
If it ain't broke........
What about the old yellow stickers they used like on Allan Moffats XC Cobra, Can you get something like them these days ?
Visitors welcome
Relatives by appointment only
buggerlugs is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2009, 08:25 PM   #9
Ibrox90
Ibrox90's Avatar
YES! ! !, not sure where though a mates dad has one on his 351 XF
Not to sure of the process your describing ???? :S bit more detail???
HIS
THUNDER
2004 BA XR8
Blueprint
Mods:
HERS
FLASH
BA MKII XR6 Turbo
Phantom Purple
Typhoon front end
Old 30-09-2009, 10:41 AM   #10
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
Maybe just get a professional sign writer to throw it on?
There is a company in SA call DZignFX ran by Ex-V8supercar driver Simon Wills, if anyone can make or fit the real deal to your car it should be him.
http://www.dzignfx.com.au/index.html
FPV8U is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2009, 11:49 AM   #11
Eu-GenixX
Eu-GenixX's Avatar
check youtube too for vids explaining how to apply decals... thats what i did when i put my rear stickers on...
Eu-GenixX is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2009, 02:01 PM   #12
Outback
What do you use if you don't have a credit card?
Outback is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2009, 02:34 PM   #13
Nickxb
XB in progress
Maybe your licence :
Nickxb is offline   Reply With Quote Multi-Quote with this Post
