10-02-2010, 02:47 PM | #1 | ||
Ive been told to start burnout in 2nd gear (p/glide) but i find it takes a fair bit of pedal to break traction then it hits the limiter. Its also hard to hold the car still before it starts to spin. Ive been goin from 1st to second for years no probs. Car weighs 3000lbs and has 850 d/pumper and 31 1/4 x 12.5 x 15 slicks. My limiter is not a burnout limiter its an over rev limiter set at 7200.
What are other racers with heavy carb cars doin, ive noticed a lot of super sedans going from 1st to second? Is it carby vs load thing?? Cheers
Tyres are evil and must be punished |
10-02-2010, 02:53 PM | #2 | ||
Do you use a "line locker" on the breaks?
"All my life, I have searched for a car that feels a certain way. Powerful like a gorilla, yet soft and yielding like a Nerf ball. Now, at last, I have found it" Homer. J. Simpson....... EF Project, SIX666 - ITB's + Turbo |
10-02-2010, 03:10 PM | #3 | ||
no line locker and no burnout limiter
10-02-2010, 03:36 PM | #4 | ||
If its a powerglide you MUST start in 1st, then go into second if it has the power. You will burn out clutches pretty quick starting in 2nd in an auto.
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car BA GT-P for the shed Mustang GT for the other half E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it. BA XR6T for a daily NT Pajero for the bush XB 4 door project- swallows a BF xr6 turbo My dad is a generous bloke. He gave away his dead car batteries free of charge.... |
10-02-2010, 11:35 PM | #5 | ||
how bout for a rwd carby car with a manual and no line locker? any tips for a static burnout?
11-02-2010, 08:35 AM | #6 | ||
second gear, 4,000rpm dump clutch then quickly onto the brake pedal, but not too hard on the brake or you will stall it. It is a fine balance between throttle (not flat to the floor), brake (not stopping wheel spin, but not allowing it to roll forward) and steering to make sure you do not go too sideways - which will require you to roll forward a bit.
It takes a lot more control and practice in a manual. A line-locker and locked diff makes it so much easier - no roll forward and no sideways slewing.
11-02-2010, 09:10 AM | #7 | ||
COPB8
i have an auto burnout rig which used to be manual, and i changed it for that reason, i was sick of sitting sideways in the seat putting my right foot on both the brake and accelerator.
i agree with GTP owner either remove the rear brakes if its dedicated burnout car or get a linelocker, and not much point if u do not have a locked diff or tight lsd. also a low ratio diff will help u grab second easier
BF MkII XR8 Stainless manta catback exhaust with pacemaker 1 7/8 extrcators and highflow cats, Big Mouth CAI, CAPA custom flash dyno tuned, helix spacer, K&N high flow panel filter, running kingspring sl fronts and ssl rears 265rwkw 358rwhp So Far... They say less talk more action, I say more torque less traction!
12-02-2010, 10:35 PM | #8 | |||
But I suggest that if it's not working in yours go back to your way. Get wheels spinning in low in water then at around 3500 - 4000 change to top gear. It's probably what you were doing before anyway. Change up as soon as the engine wants to shift up. |
12-02-2010, 10:43 PM | #9 | ||
Broken
Pardon my ignorance, but what does a carby have to do with it?
Won't any powerful car, regardless of induction, turn the tires?
The Scud GT 11.4 @ 128, 1.88 60ft. |
13-02-2010, 01:55 AM | #10 | |||
2005 BA II GTP
When my BA II GTP was PD super charged making 440kw at the rears, with 4.11 diff gears, 6 speed manual, MT streets is was hopeless getting decent heat into the tyres, hence the crap times and 60 footers. We checked the tune and altered the torque tags but no improvement. The car was making a bucket load of torque! My friend who has a wealth of experience steering manual applications also could not overcome the issue????? Cheers, Paul. |
13-02-2010, 11:21 AM | #11 | ||
Tribal Elder
You can make a "hockey stick" type hand operated brake lever like the old dragsters used to use, Had one on my old manual drag car. Or just install a line locker.
13-02-2010, 02:20 PM | #12 | |||
Clevo Mafia Inc.
15-02-2010, 08:56 AM | #13 | |||
If you have efi, then it is much less likely to bog down and backfire through the inlet system. There will be more grunt available at lower revs. But ultimately, it is the revs and the power produced at those revs, and the gearing that dictates whether it will bog down. So a 1000hp NA monster with 2.9 diff gears, 2,000rpm stall and a 3 speed auto will bog if you try to take off in third, then backfire through the carbies and likely damage something. Efi would reduce, but not eliminate this problem.
15-02-2010, 09:24 AM | #14 | ||
Broken
Thanks Jas, makes complete sense.
How many weeks months off from your beast turing a tire in anger? When do us Tassie lads get a 'private' viewing at your place? A couple of beers and maybe demonstration ? hahahahaahahah.
15-02-2010, 12:14 PM | #15 | |||
I think i may be able to get it together for tassienats - 1 month away. I need to do a private track test beforehand. I will keep everyone updated with the build thread. I am too scared to test it on the drive, but a few beers when done sounds good. Ian will be in that too.
15-02-2010, 12:38 PM | #16 | ||
Broken
1200hp unleashed on your driveway would be a grand way to spend a sunny arvo with a refreshment in hand.
cheers
16-02-2010, 12:56 AM | #17 | ||
COPB8
i agree with tex, can't go wrong with a refreshment
