Old 21-09-2009, 10:11 PM   #1
dave_vic_ozz
Default Focus shockers and springs
http://www.proven.com.au/download/sp...us-rsx-kit.pdf
I was looking at this but I am sure there are more brands out there.
Can you link them here please as I need adjustable front shockers and springs please?
Dave D.
dave_vic_ozz is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2009, 10:47 PM   #2
dave_vic_ozz
Like these but for the Australian May 2005 onwards model. (52mm tube base)
http://cgi.ebay.com/ebaymotors/MEGAN...=p4506.c0.m245
Old 22-09-2009, 12:07 AM   #3
DZFord
DZFord's Avatar
HERE are some good options (not all for 2005 model but check the manufacturers for an updated list of products)
Old 22-09-2009, 01:45 PM   #4
BlackLS
yum
http://www.european-parts.net/catalo...UD&cPath=58_79
Bilstein look the go.
2005 LS Focus LX
250,000kms.
Old 22-09-2009, 02:03 PM   #5
DZFord
DZFord's Avatar
Yeah if you're willing to spend, definitely the Bilstein or the Eibach coilovers.
Old 22-09-2009, 04:12 PM   #6
dave_vic_ozz
you need external adjustment.
Old 22-09-2009, 06:45 PM   #7
Dustproof
Dustproof's Avatar
I have used Spax previously in my SportSedan and they seem pretty good.
1400 GTR Goes like it has a Kwaka up its butt
Dustproof is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2009, 03:44 PM   #8
dave_vic_ozz
O.K. I have leaned a lot here.
For the front shocks on a 2006 + model with the 52mm Upright / Knuckle. -
DamperTech.co.uk can do adjustable coil over and rebound for about $900
or
Adjustable coil, Rebound and Bump for $1500 (incl $200 odd in duty and GST!!!! [check it first]) delivered to Melbourne.
These are GAZ shocks. GAZ are ok but there are better and a lot worse out there.
Dampertech get a good rap from many kit car builders.
I am looking at a local engineering mob who do Bilstein, so more soon. The issue I have with these is you have to pull them apart to adjust the bump and rebound. There is no external knob like many other manufacturers on the cheaper models.
Dave D.
Old 27-09-2009, 06:46 PM   #9
DZFord
DZFord's Avatar
You're probably aware, but I've read on here that the Focus requires a rear camber kit when lowered > 30mm.
PS - why is the adjustable set up required? Are you taking it to the track?
Old 27-09-2009, 07:40 PM   #10
dave_vic_ozz
Thanks for the tip but mine is a little different.
I hope to build this.
www.wr4.co.uk
Here is my power plant. 2006 Ford Focus. TORQUE and POWER perfect for this sort of car.
Double wishbones on the rear are problematic. McPherson Strut will work better.
Here is a balsa test chassis to meet the Australian Design Rules on stiffness.
Hot glue and balsa about 300mm long. A few more changes to make.
Dave D.
Old 27-09-2009, 11:12 PM   #11
DZFord
DZFord's Avatar
Haha just a little different to a Focus! Very impressive.
Good luck with the build mate. You'll have to keep us updated.
Old 28-09-2009, 11:11 AM   #12
dave_vic_ozz
Will do.
The Duratec motor in a Caterham (Lotus 7, Westfield, Arrow, kit car ) is the 5th fastest around the Top Gear Track.
Ford Focus has an Awesome motor.
http://www.youtube.com/watch?v=6tN6_xUL8j4
Old 29-09-2009, 12:17 AM   #13
DZFord
DZFord's Avatar
It is a great engine, even Cosworth realised its potential and has produced a truckload of performance parts for it. Speaking of which, are you thinking of modifying the engine in any way?
I've seen that top gear clip, brilliant. Have you seen the Fifth Gear review of the Caterham CDX vs the Renault R26-R? http://www.youtube.com/watch?v=bRLefZIINCo The Caterham is a rocket, and a real handful!
Old 04-10-2009, 11:07 PM   #14
dave_vic_ozz
I will look at the links, Thanks.
I am going to keep it standard. Mainly for ADR compliance.
The main issue I have had is getting the right front end. I think I solved it but finding a Toyota Supra front but it will need a few mods for the ABS and 5 X 108 PCD to fit my Focus wheels on.
Supra on the left and Focus on the right.
The main issue is getting the top ball joint fitted in place of the McPherson struts. I would need to make a bracket to go from the old shocker clamp back towards the wheel.
I am still tempted to use the McPherson strut on the rear but mounting it will be the challenge.
Dave D.
Old 05-10-2009, 08:26 PM   #15
DZFord
DZFord's Avatar
How keen are you on using the Focus wheels? 5x108 is a rare PCD, so it may be easier to use the Supra PCD, as more wheels will be available for you if you wish to change them in the future, eg. racing wheels.
Old 11-10-2009, 09:13 PM   #16
dave_vic_ozz
You make a good point.
I was at a wreckers today and had a better look at the Ford Taurus. It has the 108 PCD. Better still it has bolt on bearings. Unfortunately the CV joint spline is larger. ( Taurus V6 )
Taurus. The bearing bolt on. The upright is aluminuim too so very light.
Focus front - the bearings are pressed in.
The Supra rear has the larger spline. I need to do a lot of research on getting custom CV joints made up. Not a way I want to go. Add thinking music here.
As for the wheels. These ones on the Focus are very light anyway. I am keen to use them. I like the look too.
Has anyone painted them for a different look. If so please post a picture.
Old 11-09-2010, 04:40 PM   #17
20focus05
I wanna XR5
20focus05's Avatar
There is lots of parts from Uk mob called Burton Power.
A bloke in Adelaide uses the Duratec for Clubmans he builds.
I went to his workshop(Jaguar) and he had paper work for a bolt on Quad throttle body for the Duratec, a 50Hp Bolt on!!
Heres a link to BurtonsHere
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2010, 10:38 PM   #18
dave_vic_ozz
thanks - was that Aaron?
Dave d
Old 13-09-2010, 09:06 PM   #19
20focus05
I wanna XR5
20focus05's Avatar
Jeff from Sovereign Auto on Angus st.
I went there to get info on old jag I was working on.
Old 13-09-2010, 11:51 PM   #20
DZFord
DZFord's Avatar
Was it this kit here? http://www.omextechnology.co.uk/Thro.../Duratec20.htm
Burton sell this kit, the stuff dreams are made of!
