#61 | |||
Back on the road
Because the lockup clutch is very small, it is generally only applied when the car is cruising > 80km/h with very low throttle percentage. The lockup clutch is controlled by the EEC, and as Stav and Casper have hinted at, can be fooled easily with resistors and other electronic things I don't understand...lol.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#62 | ||
![]() Join Date: Dec 2004
The lock up is a simple 'on/off' switch signalled by the ECU. Even has its own wire to do it. All that is needed to disable it is to fit a toggle switch after the ECU that breaks the connection. That way the auto never gets a signal to lock up.
I recommend not messing with it in normal driving as not having a lockup is a pig on fuel. Useful for the track though if your engine has enough power to compensate... which mine doesnt.
#63 | |||
Smile
0.7 seconds is 0.7 of 4.1..isnt it.1 second is the gap at 4.1? This equals 2.7 metres gap for a 14.9 pass not 29..? Confused me with all these maths..never was really good at it anyway. My car wont run a 14.6 mate.??Its not the batmobile!! I am now aiming for a pedestrian 15.7 1/4
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() Last edited by Stav; 09-10-2005 at 11:07 PM. |
#64 | |||
#65 | ||
Smile
Well..for the street this converter has been great on takeoff but not so powerful midrange.The stall speed is 3200 rpm. Off the line I haveyet to be beaten.I believe my 60ft times would be one ofthe quickest if not the quickest out of an AU auto in this country.Unfortunately we will never know.I am taking it back out.
I do not believe that a 3200rpm stall is good for the AU six.I believe that the ideal stall speed is 2500 to 2700 rpm.Whoever gets more is destroying their usable power band. If you want to be the red light king..this is the converter for you. As mentioned before I have pass everycar off the mark by 2 to 6 car lengths..its great fun. My 0-100 before stall was 6.9 seconds.Now it is 7.45. The stalled AU now would beat my standard AU by 2 car lengths at the lights but be the slower to 100 kays. I am quite determined to get rid of this but enjoy the getaway. After timing my vehicle today I am heading for a 16.8 1/4 mile due to this unit. It flings me forward,1st gear diaapears,then goes into second at 3200 rpm and locksup ..but too late then hits third at 3200 rpm and flies to 5500 rpm. Thos converter would accelerate my car much better if it was made to stall as requested at 2500-2700 rpm.Off the mark it would not be as fast but would be better to 100 and the 1/4.So there you go..bigger is not always better.The only other thing I am thinkng of is to get some 3.7 gears to make this work better..
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#66 | ||
try it with the 3.7 diff gears before you take it out .
i can't see how it should slow your 0to 100 time down ,you'd think it would be quicker cosidering your lauching harder off the line |
#67 | |||
Smile
#68 | ||
Smile
Is the gtech stuffed?
#69 | |||
Back on the road
I don't really understand what you mean when you say,
What rpm are you shifting at? If you where shiftng at 5500rpm, I wouldn't have thought the engine would drop that low into next gear...what are the ratios in the BTR 4-speed again? What size where the SP300's you put on? I still think you need more rubber...and change gears manually. I need to see this car before you rip it out.
#70 | |||
Smile
sp300 205/65/15
#71 | ||
Smile
Well tonight I redesin\gned some tracks in the ecu and the car is screaming again...thank heavens!!
#72 | ||
hey useless or someone else... would you be able to tell me something, since you seem to know way more than i, and i dont want to start another thread for nothing.
i have an i6.. non VCT.... I seem to have 'standard' power from 1000 rpms to about 3800rpms. after that is goes absolutely stupid and pulls like nothing else, only mods are k&n panel filter, 2.5' mandrel bent exhaust. is there something i can do to get that power right across the rev range? to get the most out of the car i have to drive it manually changing up on the red line. i imagine its no good... but the quicker the dif goes.. i guess i can look at something else! hehe. when you say you re-mapped the computer, is that an aftermarket chip? AND.... i take it you dont really recomend getting a high stall converter if your not drag racing with your car yeah? |
#73 | |||
Smile
A stall converter will be good if its not too big.
#74 | ||
ok, jmm extractors and uni chip it is!
i have finally given in to the engine mods... i just HAVE to do more! thanks mate good luck with your beast! cheers Rob |
#75 | ||
Just go with the manual conversion. It's fun, you have full control of rev (thats captain obvious) and shouldn't be too much more than this. Most people do it for a touch under $2000.
Looks like a good product though. |
