12-10-2005, 09:12 PM | #1 | ||
A couple of quick questions
Can the DTE on an AUII be recalibrated?? How do you you get at the antenna/aerial on an AUII? I need to replace mine. cheers |
12-10-2005, 09:44 PM | #2 | ||
Back on the road
Hmm...not sure what you mean exactly about recalibrating the DTE?
You can get to the aerial under the passenger side (front) wheel arch. Remove the plastic cover with the plastic plugs and metal tabs, then there will be a piece of foam that just pulls out, and there is the aerial ;)
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
12-10-2005, 10:23 PM | #3 | ||
Changing your driving style is a form of DTE recalibration.
13-10-2005, 08:56 AM | #4 | |||
cheers |
13-10-2005, 10:38 AM | #5 | ||
Back on the road
Is that factory LPG or Aftermarket?
The DTE is a calculated value based on fuel usage and tank size. It should technically be possible to change the value for the tank size. No idea who/how you would go about this though...Maybe AU Edit?
13-10-2005, 11:04 AM | #6 | ||
factory LPG (e-gas). I understand how the DTE works. It just seems to have a much smaller tank entered than the car actually has.
What is AU edit?? I'll start searching now. cheers steweyau |
14-10-2005, 11:09 PM | #7 | ||
With an LPG tank ... you can only fill to 90% of the actual capacity ... it's a safety feature (gas expansion on hot days). You will only be able to fill to a maximum of 90L ... (although i managed 96L .. but that's a different story).
DTE still works as it is supposed to though ... but can be flakey though ... I don't trust it 100% ... I just go off how many KMs I have travelled.
15-10-2005, 01:49 AM | #8 | ||
Two > One
LPG by law is max 80% fill. 80L tank will fill to 64L etc
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
15-10-2005, 07:00 AM | #9 | |||
16-10-2005, 10:10 AM | #10 | |||
Walking with God
Stinking thieves! GK |
