Old 10-04-2011, 08:45 AM   #1
eb falcon gl
75th anniversary
Default side door moulds
hi, would anyone know how to remove the side door moulds on an AU 2.
I need to remove one of mine on the rear because the end near the front door has lifted and bent.
thanks
LZ 2016 Focus RS in shadow black
eb falcon gl is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2011, 02:20 PM   #2
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Default Re: side door moulds
I am not completely sure but I think they are just glued on, so maybe try a heat gun/hair dryer, but be very carefull not to get the pannel/paint to hot, allway's move the gun around and don't stay in the one area.
Old 13-04-2011, 12:04 PM   #3
eb falcon gl
75th anniversary
thanks, i will have a go on the weekend
Old 13-04-2011, 12:34 PM   #4
b2tf
not here much anymore
b2tf's Avatar
Fairly sure you're right. Keep in mind that they do have holes behind them so you probably wouldn't want to leave them off and use the car in weather etc.
2024 F150 XLT
Old 13-04-2011, 07:19 PM   #5
EATHSV
Oo---oO
EATHSV's Avatar
when my painter swaped mine for the BA ones i think he said there were two screws from inside the door through said holes? May be wrong though. I'd pop the door trim off and have a look first to be sure before you start pulling at them...
AU2 Fairmont Ghia - Monsoon Blue, TS50 wheels -ongoing project.
Successful transactions with the following members:
Ride, Raised by Monkeys, TICK4D-TAS, Falcman007, 2002AU, JC.
EATHSV is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2011, 08:47 PM   #6
richo77
richo77's Avatar
They're a combination of the tape and bolted on, access by removing your door trims.
Cheers Nathan
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2011, 08:52 PM   #7
aufalco
Alternator
they are just glued on they will just pull straight off pretty easily
i havent seen any bolted/screwed on before
cheers
aufalco is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2011, 09:33 PM   #8
SlipKnoT
i know they plug into the door atleast so not sure about bolts but will deffinately be holes under them
SlipKnoT is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2011, 10:14 PM   #9
aufalco
Alternator
yeah there are definitely holes under them and the moulds have plugs or tabs or whatever you want to call them but they dont really do anything to attach them at all they are probably just there for alignment its the glue that holds them on
