Blue Power Racing Developments The home of Blue Power. Website Link |
What are HLA`s
Never drive faster than your guardian angle can fly but fast enough so the devil don't catch you! |
Hydraulic Lash Adjusters (lifters). Could be the timing chain tensioners, the replacement of the old plastic ones will stop startup noise. The o-ring fails on the early ones causing them to bleed down and release tension on the timing chain. $250-$300 in parts, $500+ in labour.
Oh crap I`ve had them replaced, & It still makes the noise on startup till the motor gets warm any idea`s?
Is it just the 2-5 second rattle on a cold start in the morning? There are a few cases of guys replacing the HLA's at around $45 each from Ford. I would definitely get it seen to by one of our Forum Sponsor experts who have dealt with these beasts before.
#5 | |||
![]() Join Date: Mar 2005
are you talking about the timing chain tensioners? they make a bad rattle on start up
03 BA Pursuit Blue Power Racing Developments (03) 93053000 Ray Prescott Auto (02) 49902488
#7 | |||
it`s not until you put it in gear & put a load on it till you hear the ticking noise then it goes away when the motor warms up! Iv`e tried 0w-30 & 10w-30 but it did`nt make a difference! the oil gets changed every 800km because I do stuff all kms between services, should I try 0w-40 castrol next? or will this make no difference ![]()
Could be a good idea to let it warm up for a few minutes before you drive it and give the oil a chance to circulate before you put a load on it...oil pressure?
Maybe, just maybe... you should warm it up, find a secluded area... and do a massive skid to blow out the cobwebs, lol...
How many HLA`s are there in the motor & are they easy to replace?
