Old 06-07-2011, 05:34 PM   #1
XR27
Tickford XR8
XR27's Avatar
Default Msd alternator into au xr8
Hi guys, iam thinking of putting a msd alternator
Into my au xr8. Has anyone done this? what amps
do I need, 130 amp or is better to go with 160 amp.
And are there brackets for this or do I need to make
Them?
Any help would be great.
Thanks Pete
XR27 is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2011, 06:31 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Default Re: Msd alternator into au xr8
Im fairly sure the stock one is 130amp.
2024 F150 XLT
Old 06-07-2011, 07:09 PM   #3
XR27
Tickford XR8
XR27's Avatar
Thanks for the reply,
Can i put a 160amp if thats all i can get in msd, or is it best to stay with
130?
Old 07-07-2011, 02:33 PM   #4
b2tf
b2tf's Avatar
Im no auto parky but if it was me I would stick with 130amp given that the system is designed for that. Maybe PM KOUPE76, I think Mick was going to put an MSD alternator on his old ute. Not sure if he did it or not but he might have some more info to help you out.
2024 F150 XLT
Old 07-07-2011, 05:00 PM   #5
Sox
RIP...
Sox's Avatar
If you aren't having any issues with battery charging, then there's no need to go to a higher capacity Alternator.
The only reason you might need more capacity is if you have a high load device such as multiple high power audio amplifiers.
Otherwise 130a is more than plenty.
In saying that, no harm will be done with more capacity, there's just no advantage if it's not required.
Oval Everywhere...
Old 07-07-2011, 05:17 PM   #6
AUIIPURSUIT
pursuit ute baby
AUIIPURSUIT's Avatar
where from, how much? also whats a good recommendation for starter motor, if i can avoid being ripped off from ford with an suitable alternative..
cheers.
my ride : AU xr8 pursuit ute
AUIIPURSUIT is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2011, 09:48 PM   #7
MarkT83
MarkT83's Avatar
If Your running an under drive pulley kit id prob bump it up to 160amp.
MarkT83 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2011, 04:23 PM   #8
b2tf
b2tf's Avatar
AU's are underdriven from factory. No need for a kit.
2024 F150 XLT
Old 08-07-2011, 04:57 PM   #9
Sox
RIP...
Sox's Avatar
I doubt that.
Ford would have the alternator, water pump, power steering pump, and A/C running at optimum speed for maximum efficiency at idle.
Oval Everywhere...
Old 10-07-2011, 09:54 AM   #10
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Originally Posted by Sox
I doubt that.
Sox you raise a good point, but i haven't seen any kits for au only people selling e series kits as au. The ratios on e series bolt ons must be different than au as i'm pretty sure au bolt on pulleys are smaller than e series. Because wouldn't underdrive pulleys be bigger than standard?
Old 10-07-2011, 02:46 PM   #11
Boza
Boza's Avatar
cheers.
Repco you can get bosch ones which are better than the factory ones I think they're like 150 bucks a mate bought one for his au last year
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2011, 03:30 PM   #12
Sox
RIP...
Sox's Avatar
I haven't compared AU pulleys to E series, so can't say for sure, but I doubt there would be any significant difference.
Oval Everywhere...
