02-07-2011, 09:14 PM | #1 | ||
Hi folks,
Have a problem with my Mondeo XR5 - it doesn't want to rev past about 5,900rpm although very occasionally it will still rev cleanly through to about 6,500rpm. The car is now 1 month out of factory warranty, so I'll have to dip into my pocket to get Ford to look at it. Anyone had a similar problem or have any ideas what might be causing it? I have recently installed a Bluefin remap which has improved the engine's overall performance but hasn't fixed the issue. Help! |
02-07-2011, 09:19 PM | #2 | ||
Don't know much about this, but it might help if can tell us whether it happens in all or just certain gears.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
02-07-2011, 09:22 PM | #3 | ||
Barra Turbo > V8
www.xr5ownersclub.com join up mate you will find the answer. Seems strange there is a few mondys around with bluefin installed.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels |
02-07-2011, 09:33 PM | #4 | |||
is it flat down low when cold |
02-07-2011, 10:07 PM | #5 | ||
Could be a blocked cat.
Love Fords so much, I named my son Ford!!! |
03-07-2011, 09:34 AM | #6 | ||
Thanks for the responses - will check out xr5owners club
03-07-2011, 02:35 PM | #7 | ||
MAF may need cleaning.
03-07-2011, 06:49 PM | #8 | ||
in my experience, there is no rev limiter?? i've run mine to redline a number of times...
sounds like you're running out of puff?? how's the air filter??
Ex-ride: 2010 MB Mondeo - Panther Black - Just a little bit modified New ride: 2010 LV Focus XR5 - Moondust Silver - More mods than you can poke a stick at |
02-08-2011, 09:44 PM | #9 | |||
Love the rest of the car but having driven another one - am really frustrated I am missing out on the true performance. Contact Alan(service manager at Carmicheal Ford in Townsville) and he will probably like vto here about your problem to see if its the same. Hope this helps - probably not though - Jack |
02-08-2011, 09:51 PM | #10 | ||
From memory the problem was fixed by cleaning the air filter. You would think ford would have sorted this out by now if it was the same problem. Worth checking though.
02-08-2011, 09:56 PM | #11 | ||
Found the link
http://www.xr5ownersclub.com/forum/v...hp?f=59&t=2407 |
03-08-2011, 02:15 AM | #12 | |||
03-08-2011, 07:51 AM | #13 | ||
Yep, it was a breathing problem which was sorted by fitting an ECU/airbox spacer (http://www.fordforums.com.au/showthread ... spacer+xr5) and cleaning the air filter.
Spacer = Best $50 I've spent on the car. A couple of scratched knuckles and about an hour's work, but now the car revs sweetly. Good luck Jack. |
03-08-2011, 10:21 AM | #14 | ||
I finished up having them laser cut out of 8mm polycarbonate, they work well, the ECU cover goes back on with the 8mm plate, mines been installed since 2008 and has now done over 80,000k's without a problem, even had it back to the dealer for servicing a couple of times and never bothered to remove it, still have a few left if anybody wants one, they also fit XR5 Focus and a few Volvo models. PM me and I'll send ya the info.
03-08-2011, 06:51 PM | #15 | ||
XY,XC,XEx2,XA,EF,AU,BA,XY
I'll be sending you a PM quick smart paulie! The wife's new car is an XR5T, and one of your ECU spacers would be just the ticket to be one of the first mods!
Good work, Russell.
A sad day when there's no Falcon variant in the garage! |
04-08-2011, 09:08 AM | #16 | ||
Spacer is on its way Rastus.
08-08-2011, 02:47 PM | #17 | ||
Got the spacer Paul. Thankyou very much for that!
Your attention to detail is unreal. Everything needed to do the job, and instructions for the noobs. Even I couldn't stuff this up ;-) Cheers mate. Russell.
08-08-2011, 11:15 PM | #18 | ||
No worries Russell, gimme a call if you need any help.
16-08-2011, 08:37 PM | #19 | ||
Has your problem been solved J&V? Would be great to hear some feedback
05-11-2011, 11:55 PM | #20 | ||
Update on mine - 9 weeks down in Brisbane with Ford and have got it back fixed - told me it was wiring to the O2 sensor - do I believe them - probably not. But the problem is now rectified - not bad after 42,000km !!!!!
07-11-2011, 09:38 AM | #21 | ||
time to start enjoying the car for a change mate...
