Old 06-11-2011, 08:41 PM   #1
Barnzey
Barnzey's Avatar
Default Adding Power Windows
Hi Guys
I just brought an AU11 Ute. It does not have Power windows but I want to put them in. A couple of years ago I added rear power windows to my BA Wagon. I had to replase the interal wiring harnes to get the wires for the rear.
Can anyone tell me if the standard AU11 Ute wiring harnes has the power window wires in it. I have noticed that the PW curcuit breaker is in the fuse box. So may be the wires are there???
I know I will have to get the door harneses, switchs, door skins etc. I really need to know if I need the internal (under floor covering) Harnes.
Hope some one can help
Thanks
Barnzey is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2011, 11:05 PM   #2
rayban76
AU3 5.0L Fairmont Wagon
rayban76's Avatar
Default Re: Adding Power Windows
Hey mate, I was going to do the same before I got my fairmont, The wiring harness is not the same, you have to add the door to the standard harness in the car, Door harness has to have the power window wires.
I am selling my set of front's only door harness at the moment that I got when I was going to put the power windows in mine, it has the L & R harnesses.
heres my link if your interested
http://www.fordforums.com.au/showthread.php?t=11347569
Hope that has helped a bit.
Ray
5.0L, 2.1l Kenne Bell, Tickford T3 Heads, Crow valve springs, YellaTerra 1.7 Rockers, Comp Cam, Comp D-Row Timing, 10mm LiveWire Leads, LC-1 & Moats Quarterhorse, B&M TransCooler, Walbro 255lph Fuel Pump, King Superlow Coil Springs, John Bowe Superlow Pro Leaf Springs, K&N 4" Pod & CAI, Pacemakers, 100c Cats, 2.5" Redback, 19" FPV Rims, BF-T Prem Brakes, TS50 Bumper with DTRL's, Custom FG Bulge, BA XR Side Skirts/Rear bar
Ford Performance Club of ACT
[SIGPIC][/SIGPIC]
rayban76 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2011, 01:48 PM   #3
rag top
rag top's Avatar
http://www.fordforums.com.au/showthread.php?t=11292111
Have a look at post #23 onwards. I had to do the same thing with my AU2 ute when I did the upgrade to power windows.
