08-11-2011, 10:20 AM | #1 | ||
Hi, I tried to post this in electrical but it seems newbies dont have sufficient permissions. ???
I am needing to replace the stop lights on my AU at least 3 times a year. They continually blow. At one stage I installed some LED ones but over time individual LEDs stopped working, and they also stopped my cruise control from engaging. I have read in other places that AUs are knowing for blowing rear lights, but I am yet to find out a solution. It's not that replacing them is a pain, its more that I never know if I am driving around without brake lights until another motorist tells me. Any Ideas or solutions? |
08-11-2011, 10:33 AM | #2 | ||
Giddy up.
What kind of globes are you using, are they a cheap set from supercheap/autobarn, etc.
As I was told that the cheap ones will do this time after time, might need to get a better globe from an reputable Auto elec. |
08-11-2011, 10:36 AM | #3 | ||
And be careful how you install them.. Dont touch the glass.
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang GT 10A Grabber Blue Nite Pony Package. Due Aug 24. |
08-11-2011, 10:49 AM | #4 | |||
Flairs - Truckers Delight
how many volts is your alt outputting?
08-11-2011, 10:59 AM | #5 | ||
Thanks for the responses guys. The globes were Narva brand from memory. I might ask at Repco if they have better quality globes.
Mr Hardware, Without using a multi meter and reading the dash voltage meter, it shows about 14.5 volts. (How accurate are those meters?) |
08-11-2011, 11:02 AM | #6 | ||
i don't trust any of my cluster guages.
get a multi-meter on it. if you want long-lasting globes get some 'tungsram' ones
08-11-2011, 11:23 AM | #7 | ||
Giddy up.
Yeah the dash cluster is just a guide, not totally accurate.
08-11-2011, 11:53 AM | #8 | ||
BEN
Maybe caused from slamming the boot to hard.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels. 331rwkw. 12.7 sec stock as a rock with a passenger. Now with 620rwhp ready to run the 10 built zf, built tailshaft, corn juice all to come. The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw. |
08-11-2011, 12:34 PM | #9 | ||
Critical Thinker
I found this an issue too in the past, but when I checked my globes they were fine, the terminals weren't in good shape though with visible signs of surface rust as well as the connection of the terminals of the globe being a bit loose too. I cleaned up the terminals and made sure the points of contact were firm and (touch wood) I haven't had an issue since.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
08-11-2011, 08:12 PM | #10 | ||
Does your car have a tow bar fitted?
Reason i ask is that my old EL wagon would constantly blow the RH rear brake light... eventually i poked around and found that the brake wire for the trailer plug was connected near there. I dissconnected it and it didnt blow a bulb until i reconnected the wire (almost immediately).
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
08-11-2011, 11:13 PM | #11 | ||
Blue ~oval~ Blooded!!!
i used to run the narva brand ones and was constantly blowing lhd brake light globes, switched to motorcraft (part # elb380b) and never replaced one since.
Give me fuel, give me fire! 50th Anniv G6E Turbo in Sensation Cobalt blue 94 ED XR8 Sprint- resto/ project
09-11-2011, 12:11 AM | #12 | ||
Our AU II Fairmont wagon used to blow drivers side brake lights every few months.
Fixed it by trading it in on a Focus.... |
09-11-2011, 01:40 AM | #13 | ||
When you are buying replacement bulbs just be sure that there are at least two filament supports.
Filament supports are the thin wire posts that help suspend the coiled bit that glows white hot. Cheap bulbs have only the end posts and are susceptible to vibrations when hot. you might pay a lot more though. |
09-11-2011, 07:54 AM | #14 | ||
Giddy up.
I went out and checked mine and what do you know, the driver's side brake light has blown...doh..
09-11-2011, 10:03 AM | #15 | |||
Repco had 3 brands there. The sales person said that Narva was the best. I wonder if they WERE the best, until they started outsourcing to China. |
