Old 18-11-2011, 10:59 AM   #1
thewonderer
Default Headlight bulb upgrade - done!
Hi,
Just to let you guys know out there that it's worth upgrading your H7 dipped beam bulbs.
I thought the lights on my MA mondeo were pretty good but could probably do well with a upgrade. So i order from ebay a pair of osram night breaker plus (thought philips xtreme are excellent choice too but more expensive) from a UK ebayer for about $25 delivered...
Taking the light out was a bit tricky but with the help of the manual and the fordwiki i got it out, unclipped the back and put them in. Difference was noticeable straight away.
It is tricky putting the light cluster back in, but give yourself plenty of time and also tape up just below the light cluster on the bumper so you dont scratch it.
good luck!
thewonderer is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2011, 06:19 PM   #2
allanv6gt
Tippy-tronic Free Zone
Default Re: Headlight bulb upgrade - done!
Surprised you would need to remove the headlight clsuter.
Surely there is an access hatch on the back of the light ?
Old 18-11-2011, 06:21 PM   #3
thewonderer
Sadly even the manual says you have to because it's too close to other components.
http://www.fordwiki.co.uk/index.php?..._%E2%80%93_Mk4
I've had a look at the battery and that looks even more tricky judging by that's installed.
Old 12-12-2011, 12:50 PM   #4
Keepleft
Mot Adv-NSW
Keepleft's Avatar
Mmm, you should try that with the MB and MC:-) Same:- out, rause!
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf
Keepleft is offline   Reply With Quote Multi-Quote with this Post
