Not sure if it's been posted or not, but , Just wondering if anyone is using the new E85 fuel ? Thinking about running it in my clevo , but want to be sure it's safe first ..
Peter Car
I think its not good for rubber fuel lines and associated fuel system parts.
Might need a few compatible parts for it, but when set up and tuned for E85 then you shouldn't have any problems. |
there will be a power gain but also increased consumption
BA mkII futura turbo 330rwkw on 13psi using standard N/A motor, water/methanol injection and rebuilt 4spd |
#4 | |||
Lol...
Anyone using it commented yet?Apart from a few minor changes on a old car it fine to use.The biggest issue people will have is setting the carb up and thats not a mountain of ahurdle.Efi is so easy its not funny.Better metal fuel filter and larger capacity fuel system along with a compatent tuner/setup. Its not like you need to run it all the time.Once you feel the extra torque it produces you ont want to run 98/100 at the track. |
you will find more info here http://fordforums.com.au/showthread.php?t=11351485
As long as your fuel system has been modified accordingly and you have local access to the good E85 not the cheap stuff its killer. My boss picked up 40rwkw in his 13bt by switching to E85 (240rwkw-280rwkw)
#8 | |||
you don't need teflon lines. we have used Speedflow 100-series for nearly 2 years, i know alot of guys in the US running similar for 3 times longer without any problems.
Brilliant, then I'm good to ! I am using the same speedflow 100 series lines and fittings. By any chance is your name Joe or is that your brother?
#11 | |||
Cool thanks Paul, Joe took me for a run when I was 15 in his old black capri in the 302 days when Gomack was doing his machining in Schofields. Say gday to him for me, never forget that trip round the block
Cheers, Grant |
#13 | |||
![]() you hear alot of stories about E85, from what i have gathered cars/hoses etc made in the last 10-15 years are fine with E85. you won't pick up as much on E85 being NA. best is to try and find someone who deals with E85 a bit. might be hard finding an NA carb guy with E85 experience. |
#14 | ||
Critical Thinker
Been using a blend of E85/eflex and 98 on my car on every tank for the past year and a half and have had no issues. Better power, cheaper to per tank and I get about 420km out of a tank in city traffic. Not the best consumption by any means but not bad either.
All I have is 36lb injectors, walbro 255 pump, stock lines, metal fuel filter and a good tuner.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
