Old 08-01-2013, 12:28 PM   #1
twr7cx
Member
twr7cx's Avatar
Question Rear brake upgrade options for AU3 ute?
Matt, considering that there are issues with fitting the 4 piston Brembo's to the rear of the AU3 utes due to the bearing failures and pad knock off, are there any alternative upgrades available beyond just braided brake lines, rotor and pad upgrade? i.e. is there a twin piston calliper upgrade or anything else available?
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car.
Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw.
twr7cx is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2013, 01:58 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Rear brake upgrade options for AU3 ute?
You can run the 303mm BA single piston set up and i have heard some people have run the single piston 328mm set up but this requires a little work as i am sure it fouls on the backing plate.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 08-01-2013, 10:00 PM   #3
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
Yep, it fouls. Did on my IRS setup when fitting territory spec 328mm gear anyway. Easy to sort though, but not exactly show quality once bent out of the way and then back over the new calipers. With the IRS setup it's very tight fit between the toe adjuster, the backing plate and the rotor...but doable.
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
