Old 03-02-2013, 07:03 AM   #1
robp
Default AU11 suspension knock?
Had this car fron new . When vehicle is well warmed up and going slow in traffic (up to 30KM per hour) there is a horrid more or less continual knock from the rear. I have checked and renewed brake pads and visually the suspension seems fine. This has gone on for years, but as it does not happen all the time I just put up with it. Can someone please tell me what the likely cause is please?
robp is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2013, 09:13 AM   #2
hagarone
hagarone's Avatar
Default Re: AU11 suspension knock?
It sounds like your exhaust pipe is hitting some where.Grab the end of the pipe and give it a shake.
hagarone is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2013, 09:20 AM   #3
robp
Definitely not the exhaust pipe.
Old 03-02-2013, 09:35 AM   #4
hagarone
hagarone's Avatar
IRS upper shock mounts.
Old 03-02-2013, 09:44 AM   #5
hagarone
hagarone's Avatar
Bounce the back of the car up and down, if it's soft it's a good chance it's your IRS upper shock mount.
Old 03-02-2013, 01:35 PM   #6
robp
The rear end is a solid as a rock.
No indication it is the shocks
Old 03-02-2013, 05:00 PM   #7
BHDOGS
wheel bearings?
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2013, 06:05 PM   #8
robp
surely wheel bearings would not knock? and it has gone on for years
Old 03-02-2013, 06:16 PM   #9
mik
mik's Avatar
how many k`s have you done?
"visually it looks fine"
does that mean you`ve had it up on a hoist or stands and done some pushing and pulling to check bushes, ball joints, tie rod ends, wheel bearings, universal joints,sway bar,etc,etc ?
Old 04-02-2013, 07:04 AM   #10
robp
Done 80000ks. Have done pushing and pulling etc many times - and as well we have to get a Warrant Of Fitness every 6 months in NZ where they check virtually all of those things very thoroughly.
It is a real mystery, and will only happen after driving for half an hour or so and at low speed. Have had FORD check it out, but of course would not do it when they test drived.
Old 04-02-2013, 09:03 AM   #11
peterljohnson55
peterljohnson55's Avatar
Have you checked to see if your spare and jack are secure?
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2013, 09:08 AM   #12
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Sounds like handbrake knock. Just pull up very gently on the handbrake when it happens and see if this gets rid of it. If it is, you just need to adjust the handbrake shoes. Whilst your there, it doesn't hurt to put some grease or anti seize on the ends of the brake pads where it meets the caliper to stop the dreaded low speed brake squeal that often occurs after a handbrake adjustment.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2013, 09:18 AM   #13
peterljohnson55
If you have a loose baffle in your muffler, then it may well rattle until it gets really hot and/or until a strong flow of exhaust is pushed through it.
Old 04-02-2013, 01:28 PM   #14
robp
It is really good that so many people have offered suggestions.
The entire exhaust system was replaced last year (and it is a knock, not a rattle)
It is definitely not the spare or jack.
I have not tried the handbrake and will do so (although I replaced the brake pads about 3 years ago as I hoped that might solve the problem(not!)
Old 04-02-2013, 01:59 PM   #15
peterljohnson55
Is it possible to disable the handbrake without causing any mechanical grief or safety problems? Then give it a rip and see.
Old 04-02-2013, 03:37 PM   #16
rag top
rag top's Avatar
Check your rear caliper sliders. Was the source of my hard to find rear of vehicle knock. took 4 different workshops to find it.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
Old 04-02-2013, 05:18 PM   #17
rowan194
Doesn't the AU use a separate shoe for the handbrake?
Do you get shuddering when braking hard? Could it be warped rotors?
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2013, 05:27 PM   #18
robbyj
Rob
robbyj's Avatar
wheel bearings can knock. I had a knock in my front left.
Wheels are on properly?
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2013, 06:02 PM   #19
mik
mik's Avatar
80,000 k`s is very low k`s for an au, the suspension very robust on these things, wheel bearings in my experience don`t even start to get noisey untill after 100,000 k`s, did my tailshaft uni`s at about 160,000/180,000 iirc for the very slightest of movement, do you have any mods RobP??
Old 05-02-2013, 07:03 AM   #20
robp
The Fairmont was purchased in 2011 - I am an older guy, now retired hence the low kms.
No mods to vehicle and no shudders under hard braking. The difficulty about this problem is the intermittent nature. I can drive around town for weeks and it will not happen. However go/return on a long trip and slow down to crawling pace in heavy traffic back in the city and away it goes.I will check caliper slidings and handbrake.
Old 05-02-2013, 01:04 PM   #21
mik
mik's Avatar
that`s rather tricky RobP, the only think i can think of is something has been missed, your gonna want to slap me , but all i can suggest is to double check over all of your work/mechanics work, ..........mechanics are not infallible and can miss things, let us know how you go, good luck.
