Old 29-04-2014, 05:17 PM   #1
shoop
Default Cleaning the rear light cluster on an MC hatch
One of the rear clusters in my MC hatch has got quite a lot of dust inside, coating the reflective parts and building up at the bottom. I am planning to take it off the car and rinsing it out to get the dust out from inside. Getting the light custer off seems quite straight forward (bolts accessible behind the trim on the inside of the boot, lights can be disconnected/removed) - does anyone see any problems with my plan? I'm concerned that I won't be able to remove all the electronics, the water might damage the light or that it won't dry properly afterwards.
shoop is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2014, 01:59 AM   #2
cobrin
Challenge Accepted!
cobrin's Avatar
Default Re: Cleaning the rear light cluster on an MC hatch
I know with the MB, you remove the connection and globe holder then it's just the three mounting nuts and it's out, it's all plastic from there on in so you can completely submerge in water and let dry.
Old 01-05-2014, 03:28 PM   #3
allanv6gt
Tippy-tronic Free Zone
I think the MC had LED rear lights. No idea what this means in terms of construction - led 'bulb' or moulded in at manufacture?
allanv6gt is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2014, 08:41 PM   #4
shoop
Thanks! I think only the Titanium has LEDs. Mine is a lowly LX with incandescent bulbs.
Old 11-05-2014, 01:57 PM   #5
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
My MC (Zetec) Hatch uses LEDs for the tail light "arch" & brake lights. The inidcators and reverse lights are normal globes.
Although there are two indicator globes per side, probably for redundancy.
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
