I bought my car at 37000kms I have had no service books. It is coming up to service time at 85000kms having been serviced at 10000km intervals up until the last 1 that was at 15000km. Of course give or take a 1000. I have a few questions now.
1.In the past I have serviced all my cars. Only thing I havent done is transmission services. So will the car be looked at in a bad light if I do the service myself come sell time? 2. Given I have no service books is it possible for anybody with a scanner to scan a few pages so that I know what I need to do for each service. This would be greatly appreciated. 3. Does anybody have any recommendation for a decent priced oil. For example in the past I have had bad results with the BA with Penrite. This lead to a stuck lifter so have no only used Magnatec. Good priced seems to work well. SO what do people recommend for a Mondeo diesel.
In the garage 2010 Triton GLX-R Dual Cab. So good to be back in a manual. 2008 MA TDCI MONDEO, recently became somebody elses problem haha. 1988 EA Fairmont Monza Red 3.9L CFI - the project beast. On hold for now. 2013 Nissan Pulsar ST-L - The better halfs car |
Chairman & Administrator
I assume it's the 2.0L Duratorq.
Recommended oil is to WSS-M2C913-B Specification. Service info changed at 6th month 2008 build but I'll assume it is the earlier one. Info below is for the 85,000 km service. Driving Vehicle into Workshop Instrument gauges, warning/control lights and horn -Check operation Washers, wipers - Check operation/adjust, if necessary (where applicable) Inside Vehicle Exterior and respective control lights; instrument cluster illumination - Check operation/condition Handbrake - Check operation/adjust, if necessary (where applicable) Service interval indicator - Reset Seat belts, buckles and stalks - Check operation/condition Odour filter - Renew Outside Vehicle Hood latch/safety catch & hinges - Check operation/grease Emission test Check regarding next emission test due - if applicable Under Hood Wiring, pipes, hoses, oil and fuel feed lines - Check for routing, damage, chafing and leaks Engine, vacuum pump, heater and radiator - Check for damage and leaks Coolant expansion tank and washer reservoirs - Check/top up fluid levels as necessary Battery terminals - Clean, if necessary/grease Battery Visual check for leaks Fuel filter - Drain water, if not renewed - Diesel models (with drain facility) Headlamp alignment - Check, adjust alignment, if necessary Brake fluid - Check/top up fluid levels as necessary Under Vehicle Engine Drain oil and renew oil filter Steering, suspension linkages, ball joints, sideshaft joints, gaiters - Check for damage, wear, security and rubber deterioration Engine, transmission, rear axle - Check for damage and leaks Pipes, hoses, wiring, oil and fuel feed lines, exhaust - Check for routing, damage, chafing and leaks Underbody - Check condition of PVC coating Tyres - check wear and condition, especially at tyre wall Brake system - With wheels/drums off, check brake pads, discs, linings for wear and check brake cylinders and drums for condition; check rubber components for deterioration Outside Vehicle Engine - Refill engine oil. Reset the oil change indicator, if fitted. Tyres - Adjust pressure Mobility system - check best before date on tyre sealant - if applicable Spare wheel - Adjust pressure, check wear - condition Luggage compartment lamp - Check operation - if applicable Wheel nuts - Tighten to correct torque and check for correct type. Check for rim damage Wheel covers - Check for damages, especially at retainer system Side door latches - Check operation/grease Extended Period Maintenance Brake system - Every 2 years - Renew brake fluid Air conditioning - Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning lines for damage and leaks Cooling system - Every 10 years - Drain, flush and refill with Super Plus Camshaft drive belt, tensioner and idlers - Every 100,000 km / 5 years - Renew Auxiliary drive belts - Every 100.000 km / 5 years - Renew Cheers Russ
Observatio Facta Rotae
I'm not 100% sure will have to check if its before or after 6/08, didnt realise the cambelt needed changing at 100000kms. When I was looking into them I was told by the local Ford dudes I was told otherwise. Wouldnt suprise me as they had only seen 2 MC's when I had asked.
Oh and thanks for the info.
Thanks again russ but turns out my diesel is an 09/08 build. So I'm hoping that that means the timing belt will be later.
