Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
Having trouble getting the website to come up from my home internet but comes up fine on my phone using mobile data, but as soon as I turn wifi on it cannot find the site. My PC can't see the site at all on wifi, even trying different browsers and restarting computer. All other sites work fine.
Any tips to get it working? My ip blocked for some reason?
Seduce BFII XR6T Ute ZF - Optioned interior - Hardlid - Rapidsystems V4.5 kit - GTX3576R - Crow Cams Valve springs - 1000cc KPM injectors - 20" MC Racing Wheels - DashDaq/Cobalt Gauges - 4in dump/3.5in exhaust system - Shockworks Coilovers - 30mm Swaybar - Shockworks 4pot 355mm front brakes - GT R-spec rear brakes
CPV Tuned to 340rwkw |
R51 Pathy, 91 Jayco Swan
You have been banned for putting too much power through your poor old rear tires man.
I was having a drama with the website a few weeks ago, heaps of popups and not scrolling properly. Turned out to be the wrong setting on my pc. Had to do a total reboot. |
Open up your command prompt (http://windows.microsoft.com/en-au/w...-prompt-window) and type the following.... clicking enter afterwards:
ping www.fordforums.com.au What happens after you click enter? Tell me what shows up. If you get a message saying request timed out, try typing the following and tell me what appears: ping 66.226.77.74 |
Trying to ping ford forums. I get "ping request could not find host www.fordforums.com.au. please check the name and try again.
Ping that ip and I get replies. To much to try type on phone.
That's good. What it tells us that it's a DNS issue. In other words your internet is having issues trying to understand where fordforums.com.au points to.
There's a couple of things that can be done, however both aren't considered super easy for a general user. Below are the best options: 1. Go into your network adapter settings on your PC and add the following as your static DNS: Preferred: 8.8.8.8 Secondary: 8.8.4.4 This fix however is more a work-a-round and will only resolve issue for your PC, and not everything else on your network. 2. And this is your best option... is logging into your home router/modem and changing your DNS server settings to the same as what I placed above: Primary: 8.8.8.8 Secondary: 8.8.4.4 This will tell your internet connection to use Google's servers for DNS, which will fix your current issue and any other website you haven't noticed isn't actually working for you. If you have any issues, tell me your modem's model and I'll try my best to walk you through the change. |
I'll get onto that tonight. Weird that when I went away Monday arvo it was working and come home today to it not working.
Done the usual reset modem, computer. Thanks for the help so far
#7 | |||
Using Google's DNS servers are recommended as really... when has Google ever been down? lol |
That dns setting doesn't fix the problem.
I'm on internode nbn if that makes any difference
Changed dns for the router, setting on router was get automatically from isp.
Router is netgear dgnd3700
Thanks mate. Might be worth rebooting router for change to take effect. Might also be worth checking if your changes still show on the router side after the reboot.
Done a reboot and didn't fix anything. Weird how every other website works but ford forums.
#13 | ||
Bit odd that issue is still being experienced. It definitely sounds like a DNS issue from the router end, seeing as you mentioned that your phone when connected through WiFi has same issue.
Just for ***** and giggles... we know that you can ping 66.226.77.74, so how about I get you to open up your web browser and enter that IP address in the address bar field. The Ford Forums page SHOULD display. If it does, I have a work-a-round fix which will at least get your PC showing the the forums here correctly. Only issue with this fix is if the public IP address here changes (Ie. If Ford Forums changes webhosts etc.) you once again will have issue viewing Ford Forums from your PC. |
#14 | ||
Using that ip let's me onto the site. However after logging in, it forgets I'm logged in, no matter if the password is saved.
Might have to call the isp and see if they have an idea
#15 | ||
I'm having the same issue, also with Telstra..
Did the forum move servers at all?
Current Rides: 2017 Ford Mustang 2020 Ford Everest Sport Past Rides: 2017 Kia Stinger GT 2008 FG XR6 Sedan 2008 FG G6E Sedan 2004 BA XR8 Sedan 2008 BF XR6 Turbo Sedan 2004 BA XR8 Sedan 2003 BA XR8 Ute 2003 BA XR6 Sedan |
#16 | ||
Where to next??
Could be linked to what size screen is being displayed on?
Works fine on my mobile, doesn't work on my laptop, yet I'm hot spotting my laptop with my mobile data.
___________________________ I've been around the world a couple of times or maybe more....... |
#17 | ||
Ploppy pants
I was having trouble today as well.
Fine on the phone, no good on the desktop, but other sites worked fine.
Don't wait to be told.....you need Palmolive Gold!! ![]() |
#18 | ||
Yeah, it's definitely a Telstra DNS issue..
Our Telstra ADSL can't find the forum but our business Telstra Fibre can. It seemed to drop off around 2pm Perth time (4pm EST)
#19 | |||
![]() Join Date: Jan 2005
the command nslookup will tell you if your DNS has an entry for fordforums.com.au
This command is testing my default DNS server which is my DSL router. The second is using one of Telstra's Quote:
I love Holdens.... |
#20 | ||
Spent ages on phone with internode trying different things. Could only come to conclusion the problems on the website side.
#21 | ||
Chairman & Administrator
It won't be a website side issue as we have no control over DNS resolution and we certainly haven't made any changes to DNS in about the last 5 years.
Telstra and Optus (amongst others) do have intermittent issues with their DNS servers. Cheers Russ
Observatio Facta Rotae
#22 | ||
Virtuous Bogan (TM)
I had an issue yesterday from home, roughly 4-9/10PM and I gave up. At work now so ill check again. Both PC and Mac not working...said the AFF server was down?
#23 | ||
Working for me now.
#24 | |||
The one and only
I assumed the site was down after three tries and gave up.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#25 | ||
Just doesn't make sense though. As if the issues was DNS using Internode/Telstra, the change in using Google's DNS should have resolved issue straight away.
#26 | ||
Where to next??
Same here. Didn't play with any of my settings either.
#27 | |||
![]() Additionally there is a local cache on your machine which you may have to flush. I showed you above how to validate which DNS server you are using as well as to test another DNS. Can you do that and post the results here so we can help you.
#28 | ||
Youth worker
I had a similar issue yesterday. Except no devises worked and as you can see from my location it wasn't Telstra or Optus.
I'm glad it seems fine now today. As I can't use the work around here as Google is blocked.
2007 FPV F6 Typhoon BFII, Neo. Build Number 325 2011 SZ Territory Typhoon Thread: Mr Brooksy's BFII Typhoon Territory Thread: Mrs Brooksy's SZ Territory Resurrection Old Futura thread:
Brooksy's Ex Build |
#29 | ||
As others have said, the issue was obviously fixed over night.
