Old 13-07-2014, 06:01 PM   #1
RACERED
Winding roads please
RACERED's Avatar
Default Removing ST sound symposer
Has anyone removed , turned off or blocked off the sound symposer. I'm sick of hearing it and want to try it out.
HURRY UP WEEKEND DRIVE
RACERED is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2014, 08:04 AM   #2
russellw
russellw's Avatar
Default Re: Removing ST sound symposer
You can't turn it off - it is a mechanical device.
You could (potentially) remove or block the tube however.
Russ
Old 14-07-2014, 02:59 PM   #3
aratic
aratic's Avatar
You can just unplug it.. I do it sometimes as I get tired of the sound
2013 Ford Focus ST
aratic is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2014, 03:49 PM   #4
RACERED
RACERED's Avatar
Where do you unplug it from? Hose coming out from under windscreen in engine bay?
Old 14-07-2014, 05:04 PM   #5
aratic
aratic's Avatar
No the electrical plug on the side of the symposer unit, which is at the other end of where the hose which connects in under the windscreen goes. It might be partially obscured from sight by the intake tube
2013 Ford Focus ST
Old 14-07-2014, 06:37 PM   #6
gassed250
Im sure Ford can just turn it off
Mine stopped working and required an update to fix
GH Sigma EFI 351, 394whp @6500rpm
gassed250 is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2014, 11:16 AM   #7
aratic
aratic's Avatar
Or you can unplug it for free.
But yes, the sound symposer is electrically operated and can be turned off. A lot of people get this done in their remaps.
2013 Ford Focus ST
Old 15-07-2014, 07:32 PM   #8
pajoda
pajoda's Avatar
I had mine tuned out with a new ECU file ages ago, you can buy manifold blanking plates, or you could remove the hose from the firewall plastic thing that I remove every track day to get air flowing through the engine bay, and then plug the hole with a grommet so engine bay air doesn't leak through when interior air flow is outside air.
2018 Ford Focus RS
pajoda is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2014, 11:58 AM   #9
dps1984
I have removed my unit all together and purchased a block plate from a US company called BREEDT. Definitely worth it if you have an intake and exhaust as it removes the in cabin noise of the symposer.....but that is just my objective opinion.( i just found it too loud under accel)
dps1984 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2014, 03:02 PM   #10
RACERED
RACERED's Avatar
Thanks I'll look into that
Old 19-07-2014, 05:15 PM   #11
RACERED
RACERED's Avatar
Just blocked off the sound symposer hose outlet next to the battery with a door stop of all things... test drove.... beautiful. Nice n quiet.. will still look to completely remove the setupuploadfromtaptalk1405750824684.jpg
Old 19-07-2014, 05:51 PM   #12
dps1984
Have to love Australian innovation
Old 19-07-2014, 06:01 PM   #13
RACERED
RACERED's Avatar
Haha yeah but think I should do a full removal asap... buy the parts off steeda I think...
Old 19-07-2014, 07:05 PM   #14
pajoda
pajoda's Avatar
genius
2018 Ford Focus RS
