02-05-2016, 09:48 PM | #31 | |||
I bet the vast majority (me included) of diesel owners are more likely to notice a warning on dash than anything under the hood, so Id say they're setup to avoid failure. The issue now is the complexity and cost of the system. I wonder how frequent water sensor failure is and how much they cost to replace?? Edit: bet me to it NZ XR6 |
02-05-2016, 11:55 PM | #32 | ||
Easy, if you can find it that is!
03-05-2016, 01:04 AM | #33 | ||
Challenge Accepted!
You'll need to double check OP this is all I could find for another location: Scroll down to post #30
http://www.talkford.com/community/to...lem/?p=2263994 |
03-05-2016, 02:17 AM | #34 | |||
I haven't found much on more recent MC's, but I did see that Ryco lists 2 filters for MC tdci (before and after 04/12). http://www.rycofilters.com.au/catalo...ondeo#vnote_ik |
03-05-2016, 08:48 AM | #35 | |||
It's the same as V8kado's. I posted the pics on talkford (I'm out of data allocation for pics here). So per Ryco the filter is different after 04/12. Should be easy to spot, canister with fuel lines and electrical connector about the size of a jar of pickled onions. Could have migrated to the left side. |
03-05-2016, 09:37 AM | #36 | |||
My Haynes manual (2012) says:
03-05-2016, 09:53 AM | #37 | |||
I had a good look in engine bay with cover off. Not there. |
03-05-2016, 05:45 PM | #38 | |||
Drivers side of engine under plastic cover Close up. Not sure how you get to drain screw as it sits in a casing Now on another note, where the hell is the oil filter?????? Spent an hour looking for it, nothing obvious.
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢 2008 Peugeot 308 HDi - Highway Hack II 2008 Citroen C4 HDi - Highway Hack III 2010 Peugeot 308 HDi SW - Shaggin Wagon II 2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power ! 2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone 2022 Volvo XC40 T4 Inscription - Shopping trolley II 2002 BMW R1150GS |
03-05-2016, 06:59 PM | #39 | ||
That's a very different engine to the earlier models!
03-05-2016, 08:32 PM | #40 | ||
03-05-2016, 08:40 PM | #41 | ||
Looks like a filter to me.
The fuel pump is driven directly off the exhaust camshaft on RHS, all metal, lots of pressure. I'm guessing the oil filter is where it was before, which makes it underneath the filter? |
03-05-2016, 09:44 PM | #42 | |||
Mad Scientist!
Underneath you'll see a round object with a nut on top (all black plastic) This is where the oil filter is. A real s__t to get to if you ask me!! |
03-05-2016, 09:51 PM | #43 | |||
Mad Scientist!
Also, what tolerances have Ford put into the system before you suck this water through your system causing massive bills? A simple glass/plastic indicator/bowl, with drain on bottom, could have been placed in the wheel arch (behind a flap). A simple message could be written in the manual telling you to check every month. |
03-05-2016, 11:30 PM | #44 | ||
If someone could upload a pic of one of the earlier engines with the cover clipped off I would be grateful. I understand the oil filter was to the right of the filler cap but I couldn't see it anywhere. I googled some images and found that the earlier ones had a filter underneath near the bottom of the radiator - I didn't notice it there when I pulled the splash shield off but I was distracted by an slight oil leak from my transmission.
03-05-2016, 11:37 PM | #45 | ||
04-05-2016, 01:13 AM | #46 | |||
04-05-2016, 10:33 PM | #47 | ||
Here's my engine bay - sorry for the dark photos. 11/10 build.
Honestly - I would be like trying to get to that without your migratory fuel filter hovering in the vicinity... Here're pages from the Haynes manual that helped me locate it: |
05-05-2016, 01:56 PM | #48 | ||
Found It (oil filter) !!
Hiding behind the filler tube, and almost under the fuel filter. I had to unclip the filler tube and lay it out of the way to get to the filter. Not sure how I will go changing it but I will find out in a couple of weeks.
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢 2008 Peugeot 308 HDi - Highway Hack II 2008 Citroen C4 HDi - Highway Hack III 2010 Peugeot 308 HDi SW - Shaggin Wagon II 2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power ! 2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone 2022 Volvo XC40 T4 Inscription - Shopping trolley II 2002 BMW R1150GS Last edited by bundybear75; 05-05-2016 at 01:57 PM. Reason: . |
