04-10-2016, 09:09 PM | #1 | ||
Does anybody have a pic of what an au xr8 clutch cable retainer clip looks like,its the one that clips onto the cable once it goes through the hole in the bell housing.
Im not sure if its a circlip or another kind of clip,i need to get one and have no idea what it looks like.. cheers |
05-10-2016, 07:23 AM | #2 | ||
Chairman & Administrator
Try these and see if they help....
Cheers Russ
Observatio Facta Rotae
2 users like this post: |
05-10-2016, 11:56 AM | #3 | ||
Thanks Russ,thats perfect!
05-10-2016, 07:40 PM | #4 | ||
Been to ford and they said there is no such clip,can anyone with an au v8 manual confirm if a clip holds the cable onto the bellhousing?
05-10-2016, 10:09 PM | #5 | ||
Ford T3 Partsologist
the Parts Catalogue doesn't have the the same drawing as the Work Shop Manual drawing
There is a 2 clips listed, but not sure as the MICROCAT Pic is terrible - doesn't show where they go Part Number's are 382931S (thats "S" for Sam and not the the number 5) and EA 7B617 A clip is very simular to the retaining clip used on caliper flexible brake hoses Same V8 clutch cable used as far back as EB Series 2
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org Last edited by Dingo; 05-10-2016 at 10:22 PM. |
05-10-2016, 10:17 PM | #6 | ||
Thanks Dingo ill search some more.
05-10-2016, 10:31 PM | #7 | ||
I found a couple of usa references to that number and a rough pic but its not the one im after,thanks for trying!
Its looks and sounds like a hose routing clip,almost like a p clamp type of thing. |
05-10-2016, 10:53 PM | #8 | ||
Have a look at Images of " FORD BRAKE HOSE LOCK CLIP "
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org |
05-10-2016, 10:59 PM | #9 | ||
http://www.ebay.com.au/itm/GENUINE-F...0AAOSwo0JWIBBd
I thought it looked exactly like one of those clips for brake hoses or one of these ebay ones would work if they are the correct size. Ill measure the cable slot tomorrow and go hunting! I found a few posts about mustang guys running without them but id rather have one fitted personally. |
06-10-2016, 01:46 PM | #10 | ||
I have 1 of those type retaining clips - they are early Falcon ones - ill see if it fits the groove
AU T3 doesn't use the clip but the groove is on the cable - i have my gearbox out of the car at the moment so can ill have a captain cook tonight after work
06-10-2016, 02:02 PM | #11 | ||
Yeah its quite possible that I don't even need one.
That would be too easy |
06-10-2016, 10:59 PM | #12 | ||
The V860004-S2 (the ones on ebay won't fit , to small and to thick for the groove) - but the brake pipe lock clip (front one EA to AU) fits perfect , now the T3 with the Tremec doesn't have a clip, doesn't need it - give me a call or txt on the mob number i pm'd to u and i can send some photos
