Old 07-08-2019, 01:13 PM   #1
scoupedy
Default 2014 focus rough idle
Hi everyone,
Tried searching for thread would not work.
Low km -33k 2014 focus has a rough idle.
Any help please
scoupedy is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2019, 03:00 PM   #2
marg99
Default Re: 2014 focus rough idle
have you cleaned the exhaust gas re-circulation valve?
Old 07-08-2019, 06:27 PM   #3
falconhell74
falconhell74's Avatar
Check for vacuum leaks around the inlet manifold , spray throttle body cleaner around the manifold flange and associated parts to see if the engine picks up in revs at idle.
If it does then you need to pin point were the leak is .
IE the inlet gasket to head , injector O ring etc
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2019, 06:39 PM   #4
GTLEGEND
Check for collapsed engine mount (the one under the coolant reservoir). You can tell if there is any rub marks between the bottom of the rubber and the top of the lower aluminium housing. if there's rub marks, its collapsed.
Has this vehicle had a clutch replaced? If so could also be that the clutch mounts to the flywheel have not been torqued up to the right torque and in the right sequence.
Also check spark plugs and coils.
