07-03-2021, 10:04 PM | #181 | ||
07-03-2021, 10:06 PM | #182 | ||
07-03-2021, 10:13 PM | #183 | ||
Former BTIKD
Go and make a Coffee, GT will have it for you shortly
07-03-2021, 11:50 PM | #184 | |||
LHF Frame Mould: $130 RHR Frame Mould: $210 LHR Frame Mould: $200 RHF Top Door Mould: $130 LHF Top Door Mould: $150 RHR Top Door Mould: $160 LHR Top Door Mould: $160 Postage on top of that if required, number of pieces and size along with post code will determine postage cost. Cheers, GT |
10-03-2021, 12:45 PM | #185 | ||
Would you have the auto dim switch number for fgx as the fg series 2 one is obsolete now.
10-03-2021, 02:44 PM | #186 | ||
Are you referring to the blinker/wiper combination switch on the steering column or the sun load sensor in the middle of the dash that changes the lights from night to day mode?
10-03-2021, 04:10 PM | #187 | ||
Hi GT
Would you mind explaining (or showing) the difference between the 2 FGX Front Bar Covers available. From a previous post of yours, the parts are: ER2Z 17C831 AF (Falcon/XR 14OCT’14 to end of production) ER2Z 17D957 CB (Turbo XR6 & XR8 from 1OCT’16). Are they the same price, and both still available? Thanks very much |
10-03-2021, 04:24 PM | #188 | ||
Ford T3 Partsologist
G'day GT
are you able to please convert this Tickford Eng Number: 8422-6C095-AA to a Ford Part Number. thanx Dingo
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org |
10-03-2021, 04:44 PM | #189 | |||
Below are the two images from the catalogue for both bars, it may be hard to see the actual difference, but you will find the AF is the XR bar which as a shell I think its the same but the grills and moulds are different colour to the turbo and V8 one. Different prices, the AF is around $400 and the CB $580, both still available from what I can see. AF FGX Front Bumper.JPG CB FGX Front Bumper CB.JPG Maybe google some images to see the difference between the two in real images? FGX XR6.JPG FGX Turbo.JPG |
10-03-2021, 04:54 PM | #190 | ||
Thanks very much GT. I wondered about the grille surround colour, but just thought it was effects of different lighting.
I appreciate your quick response. Thanks again. |
10-03-2021, 05:10 PM | #191 | |||
Sorry no good, comes up as unknown. This happens a lot with Tickford/FPV vehicles as the parts were supplied to Ford by them as a service part number so the engineering part number is not in the Ford system as such. GT |
11-03-2021, 01:53 PM | #192 | ||
G'Day GT,
excopau was referring to the sun load sensor in the middle of the dash that changes the lights from night to day mode? Apparently for the FG/FG2 this is obsolete now from Ford and we were wondering if the FGX one will fit...perhaps not? The FG Part# we have is BA19E663A Cheers BB
2015 FGX XR6T Ute - Aero Blue - Leather Trim - 6 Speed Manual 1966 Mustang Convertible - Wimbledon White - 289ci Windsor - C4 Auto - Power Hydraulic Roof / Factory AC Previous Fords: - 2012 FGII XR6 Manual Ute - Kinetic - 1984 XF Fairmont Ghia - Olympic Gold - 1987 XF S Pak - White- 1994 ED Falcon Classic V8 - Polynesian Green - 1999 AU1 Falcon S - Hot Chilli Red - 2009 LV Focus Zetec 5sp Manual - Black Sapphire |
11-03-2021, 04:23 PM | #193 | ||
Thanks bb_zetec
11-03-2021, 07:33 PM | #194 | |||
FGX also utilizes BA19E663A and are all gone as you say. Obsolete and no NOS from what I can see. GT |
11-03-2021, 08:34 PM | #195 | ||
This is likely compatible noting the similar part number https://www.ebay.com/itm/Genuine-For...UAAOSwTwtfq9z6 and https://www.ebay.com/itm/Genuine-For...YAAOSw9DNgLZuf and https://www.ebay.com/itm/Genuine-For...UAAOSwyDNdt8gm etc
regards Blue |
12-03-2021, 12:50 PM | #196 | ||
Hi GT -
Looking to source sunvisors, their clips, vanity lights, sunglasses holder and map lights, and centre roof lights plus handles from an FGX in shadow grey. Are these still available? Thanks! |
12-03-2021, 01:07 PM | #197 | |||
Have a look at the images below and tell me part ID numbers for a start and we will take it from there. That way i know for sure what you want. FGX Roof Lining Visors.JPG FGX Roof Console.JPG Cheers, GT |
12-03-2021, 04:20 PM | #198 | ||
Message sent thanks.
2022 RAM Laramie 5.7 V8 Here & awesome! 2023.50 Ranger Wildtrak 3.0 Premium Pack, 20 inch wheels. 2024 Everest Sport 3.0 V6 Touring Pack |
12-03-2021, 08:28 PM | #199 | |||
At least we know now they are NLA.
12-03-2021, 08:30 PM | #200 | |||
I wonder if this part fails often hence there are none left?
13-03-2021, 08:46 PM | #201 | ||
I have just ordered this sunload sensor from ebay USA https://www.ebay.com/itm/Genuine-For...UAAOSwyDNdt8gm I will let you know here how it goes compatibility wise. I will also test it and pull the old one apart to see what light dependent resistor or similar component it uses. EDIT: Damnation just found it cheaper here: https://www.fordpartsgiant.com/parts...-19e663-a.html AU$85.15 including shipping. Ended up being able to get it there i.e. FordPartsGiant as I was still waiting for a shipping quote from the ebay seller.
regards Blue Last edited by aussiblue; 13-03-2021 at 09:08 PM. |
14-03-2021, 11:38 AM | #202 | ||
Thanks for your efforts Blue.
Looks like we will need to do this sort of thing to keep our cars going forward once parts become obsolete. GMH parts are also facing the same fate with stocks depleting and no replacements available anymore. The companies that made these parts must no longer be able to do or not have the need to make any more.
18-03-2021, 10:10 AM | #203 | ||
xr8
hi my dad is looking for the inner foam for the right front door the part that goes between the door and the door trim im having trouble finding them i was wondering if you know if you can still get them
thanks
Ba Xr8 Ute 262rwkw Crow Cams,Headers, Full Exhuast, Cai, 80mm Throttle,100mm Intake Pipe, K&N,Colder Thermostat, Tune. Back in 2011 |
18-03-2021, 11:24 AM | #204 | ||
Former BTIKD
GTLEGEND really is a Legend, however he isn't a crystal ball reader so a Vehicle type and year would be most helpful.
18-03-2021, 02:54 PM | #205 | ||
*SILVER SERVICE PILOT*
If this is for a B series car, I'd also be interested in finding out if they're still available
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
18-03-2021, 04:41 PM | #206 | |||
They are not available new anymore. You will need to try eBay or the alike or a Ford wrecker. I can suggest some places in Sydney if need be? |
18-03-2021, 05:47 PM | #207 | ||
Giddy up.
I probably already know the answer GTLEGEND but no harm in asking, are genuine leads and coil packs available for the AUII XR8 ?.
Cheers. |
18-03-2021, 07:24 PM | #208 | |||
https://www.ebay.com.au/itm/NOS-OEM-...4AAOSwY4Nep0zD Leads also no longer available. They came in two sets, 1-4 XR2E12280AC and 5-8 XR2E12281AC. |
18-03-2021, 10:13 PM | #209 | |||
xr8
it is for a 2005 ba xr8 sedan that would be appreciated if you could i’m not even sure what they are called thanks
19-03-2021, 12:26 AM | #210 | |||
Try these places in Sydney: http://www.fairfordspares.com/ https://www.facebook.com/mrfordsparesptyltd/ GT |
