#361 | ||
If this is the NTK I would like to purchase of you if you can give me details as yes it’s 6 cylinder and the one on the extractors.
#362 | ||
[QUOTE=martyt100;6586294]If this is the NTK I would like to purchase of you if you can give me details as yes it’s 6 cylinder and the one on the extractors.[/QUOT
They are genuine Ford parts, if you are interested send me a PM. |
#363 | |||
#364 | ||
#365 | ||
![]() Join Date: Nov 2011
Any chances of an FGX XR8 bonnet?
#366 | ||
#367 | ||
Seasoned Visitor
Is there any stock left for an AU series 1 V8 cold air intake pipe? the section between the MAF and the throttle body? Mine has split. I've used my spare now and looking to put another on the parts shelf.
I do not need any of the sensors, just the pipe itself. |
#368 | |||
AU V8 Air Cleaner.JPG |
#369 | ||
What would the price for the left and right guard clear indicator lens for SZ Territory?
Part Numbers: ER2Z-13K354-AA (right) ER2Z-13K355-AA (left) Cheers
2003 BA Futura Wagon 2014 SZ TS Territory |
#370 | ||
#371 | ||
Awesome, ill PM you re payment. Cheers
#372 | |||
Seasoned Visitor
#373 | ||
#374 | ||
Thanks for the response. Dealers here say that Ford not only want an XR8 vin no to release a bonnet to them, but they also want pics of the car smashed to justify the bonnet purchase. Quite unreasonable i think as some of us want a spare bonnet for their XR8.
#375 | ||
Giddy up.
What would the price be for the Pollen Filter for a SZII Territory ?and just a rough price with freight for maybe two ?
Regards. |
#376 | ||
#377 | ||
Giddy up.
Cheers mate, I'll send you a PM latter.
#378 | |||
Ford T3 Partsologist
These may be of interest https://www.ebay.com.au/itm/133719238830 ***
![]() 2002 Blueprint T3 TE50 Manual Koni Suspension # 161 ![]() ![]() T-Series Club of Australia - www.tseriesclub.org ![]() ![]() |
#379 | ||
#380 | ||
Mr GT,
Are the rear toe adjustment bolts for a BF still available and how much would they be? The ones that sit behind the diff. I've seen kits long ago that were the bolt, nut and 2 cam washers. I assume that's how they come and is what I'm after. |
#381 | |||
Yes that kit is available, $45 each side plus postage if required. Cheers, GT |
#382 | |||
I'll get back to you in a couple of weeks when I get some funds together. Thanks. |
#383 | ||
Sorry for the confusion earlier, I thought you wanted me to find the references independently and then ask about supply.
Is the green arrow only available as part of an overall assembly? Also are there better images of 16B246 or 16B247, 104A48 or 104A49? Not quite able to make out if they are the pieces sought… |
#384 | |||
No better images of the parts requested even if I try to enlarge how ever their description are below: 16B246: REINFORCEMENT - APRON CLOSING, RH, UPPER 16B247: REINFORCEMENT - APRON CLOSING, LH, UPPER 104A48: PANEL - REAR FLOOR SIDE MBR CLOSING, RH 104A49: PANEL - REAR FLOOR SIDE MBR CLOSING, LH If they are all the pieces you are referring to, I would need to check availability as I believe they are no longer available, but need to confirm. |
#385 | ||
Just nudging this, per post 383 - any dusty old stock left, including the cowl panel set?
#386 | ||
Nothing left from any of the cowling parts from post 383..
#388 | ||
#389 | ||
#390 | ||
hi GT can I get prices for FG DUAL ZONE AC mixer rod and mixer flap please?
Many Thanks 2001 AUII Factory LPG Manual XL Styleside Box High series bonnet Clear Side Indicator K&N Air Filter BAXR6T Snorkle Low Fronts, Super Low Leafs |
