Old 22-02-2016, 12:11 PM   #1
TK-421
Default AU cluster swap.
Can a s2 AU XR cluster be modified to fit a S1 XR?
thanks.
TK-421 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2016, 06:53 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: AU cluster swap.
Yes - there are small differences in plugs but with a bit of wiring modification it can be done.
Russ
Observatio Facta Rotae
Old 23-02-2016, 08:16 AM   #3
Blue Shadow
R.I.P. Maggie
Blue Shadow's Avatar
Russ
Geres another one; is an S2 cluster the same as an S3?
AUII XR8 200Kw Ute
FG XR6T
1976 289 Mustang (Gone)
Blue Shadow is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2016, 08:43 AM   #4
Sox
RIP...
Sox's Avatar
Yes.
Oval Everywhere...
Old 23-02-2016, 08:44 AM   #5
Blue Shadow
R.I.P. Maggie
Originally Posted by Sox View Post
Yes.
Thanks Sox
AUII XR8 200Kw Ute
FG XR6T
Old 23-02-2016, 10:15 AM   #6
Fyrestorm
Spanner Thrower
What plugs are different Russell? Or just a moved pin here and there? (S1 futura with a s2 Fairmont cluster. Did have to move 4-8 wires.)
1999 AU Futura Wagon (Nickname Betsie the Barge-***)
Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG.
Awaiting Wife Approval Mods:
TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things!
Fyrestorm is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2016, 06:04 PM   #7
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Look in mu 1st AU build I swapped wires from a standard loom to make a high series work.
UK
Old 24-02-2016, 05:34 AM   #8
Fyrestorm
Spanner Thrower
I knew about the swapped wires (done the same plus got the doors to light up individually)
Pretty sure the physical plug was the same though.
Old 24-02-2016, 09:24 AM   #9
TK-421
What i would like to do is swap my
s1 tickford fascia for a s2 blue cluster and have all features function,,thanks for your replies.
Old 24-02-2016, 12:13 PM   #10
Fyrestorm
Spanner Thrower
Ok so changing from a low series (it'll have speed and rpm, fuel and water temp) to a high series (adds oil pressure and battery voltage) right? 4wires need to be moved around and you have to replace the oil pressure switch with an oil pressure sender. If they both have the same gauges then it'll be a straight swap.
Old 08-09-2021, 02:43 PM   #11
El Sucio
El Sucio's Avatar
Any difference between XR ute and sedan? My cluster in the ute needs replacing, found a great same user but from sedan. Would hate to throw a code or plugs not fit.
Sent from my SM-N986B using Tapatalk
2005 BA Mk 2 Fairmont, riding dirty on Pedders Sports Rider and limo tint, rolling on 18's, hand of god pushing passengers into their seats with a tuned 232rwhp and 470Nm
Previous Rides:
KH Laser TX3
EF Futura (RIP)
EL XR6
AU2 XR6
BA XR8
BF XR8
BF Wagon (XR6 Lookalike)
2014 Ford Ranger
2000 AU XR8 with all the options boxes ticked (RIP)
G.M.H. - Get a Mechanic...Hurry!!
El Sucio is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2021, 02:56 PM   #12
fordomatic
fordomatic's Avatar
No difference mate
Proud owner of the ugliest Ford ever made
fordomatic is offline   Reply With Quote Multi-Quote with this Post
