Where would one find the chassis dimensions for a 1928 - 32 Ford? I'm starting a hot rod project, and am looking at making mostly everything myself, chassis included. I'm just after the dimensions so I can start work.
It will be a little "different" to any out there, my plans are to heavily modify the chassis for my plan to work... I'll keep you updated, obviously in a different section. So where's the best place to look? Cheers |
Google for a start.
American Stamping 8719 Caroma, Olive Branch, MS 38654 tel : (662) 895-5300 or email Michelle @ jutbl@msn.com ** put '32 rail prints in subject line. drawings are $10 USD This info was in the June 2003 issue of StreetRodder, pg.196 http://www.ebay.com/sch/i.html?_nkw=1932+ford+frame |
Are you going to want to register it?
I am, will this be a problem?
If it is, chassis mods may not be done, will it still be a problem? Sorry for the questions, its my first build of anything major apart from a Group NC Torana. |
#5 | |||
Cheers, will look into it. |
#6 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
My mates 32 sits on a Hi Lux chassis , not sure if that's a route you wish to take or not.
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
'32 rails are curved and sculpted...not exactly a make-it-at-home proposition like a Model T chassis is (that's basically some straight rectangular section that anyone could knockup).
Plenty of kits available though, and I have seen ones that are side rails and cross rails which you'd have to weld together...but you'd want to make sure you did it right. I'd be buying a chassis and going from there... |
Check out ozrodders.com
They are an australian hotrod forum. very friendly guys. They will be able to answer all your hot rodding questions. Especially chassie wise also check out http://www.asrf.org.au/ That site will also guide you as to what mods will be acceptable for street registration. If it doesnt match their requirements, dont expect to registor it, period. Assuming that is the direction you want to take. Otherwise if it is to be a drag car or show car ownly, check out cams, otherwise, mod away ![]() I want to make my own rod one day but given my current financial situation it is a little to expensive at the moment. So I am starting with a more reasonable base (ie cheaper to start of with).
Current ride Bf xr6 turbo sedan, 6 SP auto, Leather/suede interior |
If you intend registering it, hope you have done your homework and checked with your relevent roads authority.
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
Depending what your trying to acheive at the end, the original rail dimensions mite be of no use whatso ever
Most who qualify for full rod rego start with an original chassis and mod that as it qualifies as a pre 1949 So a few questions, full rego or rod rego ,can you not use a later model chassis as a donor and go down the rebody path Are you goin for an authentic style or look , or will later model style suspension not bother you ozrodders is a good site,theres plenty of yank sites,theres plenty of info out there on 28-32 fords |
![]() Join Date: Dec 2006
As Uteaddict says, ASRF is the answer. Join it, you will have the resources and contacts to do it the right way if you want to get it registered.
SR "street rod" registration under the permit scheme is pretty flexible, almost sane, but you must work with the authorities using the scheme. Working against will end in tears. 32 rail would be hard to replicate. It would be better to buy a pair of reproduction rails and add your own cross-members and suspension points to these. It would also help with registration down the track. My 2c
Oooh baby living in Miami....
Resident F1 Troll
rails arent that hard to replicate with the right equipment you can always pay someone with a ring roller to rool the rails for you
#13 | ||
Like Elks said, if you intend on doing a hot rod, it is just as easy to buy reproduction rails. And then add your own cross members, suspention components and the like. Plenty around the joint, especially for a budget of about 5-6 grand or under if i remember correctly.
http://www.rodbods.com.au/ http://www.deucecustoms.com.au/index.html http://www.cruzin.com.au/ (australian hot rod mag, there is also australian street rodding but cant find the site) Becarefull when viewing american hot rod sites. There are somethings that american hot rod builders can get away with that you can't in Australia. This comes down to different legislation basicly. Anyways, enjoy ![]()
#14 | |||
#15 | ||
Im pretty sure only SA can make youre own chassis rail's most other
state's you need original rail's plus at least 2 original crossmember's used to get reg , deffinately join OZRODDER's there's some talented guy's on there . ASRF is the only way to go to get rego . |
#16 | ||
Thanks for all your assistance fellas.
I'll keep looking into things, and see how I go. Will definitely be using this advice. Thanks again |
#17 | |||
Unfortunately putting a rod on a lux chassis is not that easy,they are changing the rule's , where the donor body must comply with the chassis original crash test and ADR spec's .Join a club first , someone there will have built simular and can help you thru it. |
#18 | ||
Performance moderator
![]() Join Date: Feb 2005
There was an episode on Overhauling where they fitted a new
chassis ....
#19 | ||
You can always go this way.
'02 Hilux running a 302 auto ![]() |
#20 | ||
Peter Car
#21 | ||
This thread from 2012 is probably not relevant any more.
Never argue with an idiot, they will bring you down to their level and beat with experience every time. |
