17-04-2006, 11:52 AM | #1 | ||
All Bran = Regular Member
(Originally put this in the suspension section but only one helpful response.
Maybe there is a greater knowledge base in here) I've decided to put 17" rims on my AUIII Fairmont Ghia (16" standard). I quite like the BA/BF XR6 rims and they seem to be selling quite cheaply s/h these days. Is there a general rule of thumb of how far to lower my F/Ghia so that it looks a bit better with 17's? What is involved with lowering my model to the suggested level? Also which shocks are a reasonable compromise between handling and comfort, with comfort being the priority? Thanks... |
17-04-2006, 12:00 PM | #2 | ||
I have found going for a Comfort Gas shock the best way to go ... when cruising it absorbs all harshness ... but when needed on mountain roads and sweepers ... these shocks will stuffen up under heavy load for better control.
Pedders and Monroe make similar shocks (and so do other companies as well). It depends on height preference though ... I dropped my ute 1.5" only (as it is used for work purposes) ... and I put 17" Territory wheels on it (upped in size from 16" rims). There's still a couple of centimetres between top of tyre and wheel arch .... but nowhere near the gap I used to have. Spring stiffness will play a part also in ride comfort too ... but if you can go a progressive rate spring it will be better for a comfort orientated ride that will stiffen up when needed for control. I wouldn't drop a GHIA too low (unless that's your thing though) ... it starts making it difficult to drive - especially if it gets taken to shopping centres and the like). Hope this helps.
17-04-2006, 12:08 PM | #3 | |||
Walking with God
All the best with it! GK
17-04-2006, 12:15 PM | #4 | ||
Miami Pilot
Do the Ghias have IRS? I think they do - if so, I have a full set of AU3 XR springs to suit IRS. Yours for $100 plus postage (approx $50, depending on where you live). They will drop the car approx 25mm from standard height. The do NOT require new shocks to be fitted as the shocks for XRs and normal height AUs are the same part number - only when you get to superlows or lower would you need to start looking at new shocks.
PM me if you are interested.
17-04-2006, 12:44 PM | #5 | ||
orgasmic.
Autobarn told me that when putting king superlows in my AU1 fairmoint that I didn't need to replace the shocks (book didn't mention anything on it) - but I think they need to be replaced anyway...
1999 AUI Fairmont Dynamic White, King Superlows, Tickford Intake, Pioneer DEH-P6850MP HU, Clarion SRC5715 5x7s (rears), Clarion APA2001 Amplifier running a Pioneer 12" Sub. 121.0rwkw |
17-04-2006, 12:50 PM | #6 | ||
If lowering a car ... if you want better control though ... it is recommended to replace shock absorbers. Especially if the height difference is over an inch at least ... otherwise your current shocks will leak under pressure as they are not designed to be matched with a shorter stiffer spring. It will work OK for a little while but the shopck absorber will fail prematurely.
Plus a Gas shock absorber will increase handling/comfort/control properties as well. If you have the funds to do so ... do it when you lower it at the same time ... it saves replacing them later on and will reduce your labour costs if you do it all in one go as well.
17-04-2006, 01:34 PM | #7 | |||
I've organised the springs from JC so I'll get the shocks you recommend as well. Funny, I thought I was over cars but I'm quite looking forward to playing around a bit |
17-04-2006, 01:38 PM | #8 | ||
No probs ... when you get older ... the word changes from "modification" to "enhancement" ... hee hee.
You still need a toy to tinker with though
17-04-2006, 06:20 PM | #9 | ||
Hi Ron,
I own a Fairmont Ghia that has been lowered with kings spring SSLs the only problem as mentioned they stuff the shocks and monroe do NOT make a shock to suit the height that i have . I cant understand it afterall the car was a optioned with the XR lowered suspension so the only way to fix the issue if you go lower like me is to get ready to fork out 700+ on stupid shocks.
18 T6 Multivan 03 Ba Xr turbo 300rwkw |
17-04-2006, 07:49 PM | #10 | ||
Flat floor shifter
Super lows and irs work well together and actually enhance the ride without compromising comfort. No way would l go sslows for a daily driver.
18-04-2006, 08:48 AM | #11 | |||
buickman
20-04-2006, 10:54 AM | #12 | ||
JC's springs turned up today... thanks mate.
Hey Mechan1k, are the shocks you are using actually called "Comfort Gas"? I had a look on Pedders website and couldn't find them. |
20-04-2006, 11:01 AM | #13 | ||
I am using Sports Ryder shocks (more sports orientated ... and stiffer).
Pedders website shows "8835 C/GAS SEALED STRUT" for the AU2 with IRS I am presuming that's for your model. http://catalogue.pedders.com.au/part...CON&model=1657 Has the full parts listing for AUII sedan with IRS ... every little thing that Pedders stocks for your model. I am presuming the C/GAS strut is the Comfort Gas strut. Hope this helps.
20-04-2006, 01:19 PM | #14 | |||
I just rang Pedders. I'll probably go with the Sports Ryders as well. Once or twice per month my wife and I like to get away for the weekend. I think I'll enjoy driving the car more with the SR's. Around half as much again compared to the Comforts but most likely worth it. Whilst I'm about it I'll replace the rotors and pads with the much discussed DBA slotted... Jeez, mucking around with cars get's a bit expensive... |
20-04-2006, 06:38 PM | #15 | ||
well, maybe I won't go with the Sports Ryders...
Just had a phone call from a guy who designs and manufactures specialty shocks (I had a guy in at work this morning and asked him who he knows in auto supply business.. "Oh my neighbour has something to do with car bits and pieces") Anyhoo, he followed it up and the neighbour rang me. Told me the shortcomings of mass produced shocks (in one ear and out the other) and will call me with a price for shocks to suit my AU. Watch this space ;) |
20-04-2006, 06:39 PM | #16 | ||
Formally Kia Chaser
You mean Falcon Fairmont Ghia right? lol
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
20-04-2006, 07:48 PM | #17 | |||
23-04-2006, 09:25 PM | #18 | |||
Woohoo... it's who you know, not what you know.... |
27-04-2006, 08:16 AM | #19 | ||
Nice work ... always good to know someone in the industry.
And you are right ... it's who you know ... not what you know. Will be interested to see the results ... what/who is the brand of shock???? Or is it a custom made item???
27-04-2006, 05:26 PM | #20 | |||
I got back to the guy I know and told him to tell the shock guy that its a deal and to let me know when and where to pickup/pay. I havent heard anything else, but with short weeks etc thats not surprising. I'll update when I've got them.... |
