Old 12-09-2023, 11:24 AM   #1
Edxr6
Default AU XR8 series 3, 5 speed manual
Guys,
When I am under acceleration especially on the incline, the car will miss, at the same time I can hear like a squeal/screech noise from the motor. Any thoughts, I have no idea at this point in time. I will do a scan check for any fault codes, hopefully this Saturday.
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2023, 12:12 PM   #2
PG2
#neuteredlyfe
PG2's Avatar
Default Re: AU XR8 series 3, 5 speed manual
Harmonic balancer.
Old 12-09-2023, 07:22 PM   #3
Edxr6
Originally Posted by PG2 View Post
Harmonic balancer.
Will the Harmonic Balancer cause the miss, it’s just the one miss. Also there is no vibration what’s so ever with the motor.
Old 12-09-2023, 07:45 PM   #4
Yes, as it slips the timing goes out.
See:
https://dannysengineportal.com/harmo...warning-signs/
https://fluidampr.com/troubleshootin...nic-balancers/
https://automotiveden.com/harmonic-balancer/
https://www.techtips.ie/Gates/torsio...on-dampers.pdf
https://www.underhoodservice.com/har...ers-fail-look/
and Youtube on how to replace it.
https://www.youtube.com/watch?v=hoI9Znd8m18
Etc
Old 13-09-2023, 08:14 AM   #5
290GTP
290GTP's Avatar
The fuel pump on my s3 XR8 would screech on occasion. Will also cause a miss.
Just a thought
Mercury Silver 03 BA GT-P Tremec TR3650 Number 534
Herrod 4 into ones, Manta Exhaust, CAI, K&N Filter, Mellings oil pump, 19" FPV alloys, Bilsteins, Kings, tuned by Autotech, 272rwkw
RIP Fish 15/1/73 - 9/2/19
290GTP is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2023, 12:31 PM   #6
Edxr6
Thanks Aussiblue, good bit of information. I will let you guys know of the outcome.
Old 13-09-2023, 12:36 PM   #7
Edxr6
Harmonic balancer.
Thanks PG2, interesting. I was more thinking of spark plug or leads. Nevertheless I am no mechanic or pretend to be one, hence this wonderful forum full of knowledge and experiences.
Old 13-09-2023, 12:37 PM   #8
Edxr6
Just a thought
Thanks 290GT.
Old 28-01-2024, 11:28 AM   #9
Edxr6
OK, update. Replaced the Harmonic Balancer and the problem still exists?
Regards
Old 28-01-2024, 12:43 PM   #10
mad2
Regular...with metamusal
Regards
as in one or both of the faults you mentioned?.
Old 28-01-2024, 01:33 PM   #11
T3rminator
T3rminator's Avatar
Missing when engine is under load (incline for example) could be a vac leak. If you get a lean code when scanning, then that increases the probability that its a vac leak.
As for the noise, a video can sometimes be useful to assist with internet diagnosis
Rides (past and present)
Old 28-01-2024, 07:00 PM   #12
Guys,
Regards
Look into the camshaft synchronizer, which have a habit of becoming noisy like that and cause misfiring. A very common Windsor issue, but also other Ford V6 engines. You can lubricate them, but the effect is short lived and replacement is the best option.
https://automotivesuperstore.com.au/...SABEgJ79vD_BwE
https://www.autopartssupply.com.au/f...CABEgLPg_D_BwE
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
Old 28-01-2024, 11:01 PM   #13
Peuty
Afterburner + skids =
Peuty's Avatar
^^^this - the screech is a good sign that it’s the issue.
Simple enough job to do mate,
Oo\===/oO
Old 30-01-2024, 12:30 AM   #14
undertow
Technical Contributor: For members who share their technical expertise. - Issue reason: AU Aux input HOW TO.
Most likely the cam synchro as above, for a test or temporary workaround you can unscrew the black cap and tip a teaspoon of engine oil down there.
Back in the day people used to buy them from rock auto in the states, but there are local options now. The very last year or two of the 5.0 explorers had the same part. The Dorman one was dirt cheap but regarded as poor quality with several tales of the gear stripping or falling off and destroying the engine. I haven't keep up recently, but the genuine Motorcraft part would be the safest bet if it's still available.
undertow is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2024, 10:18 AM   #15
Edxr6
Thanks Undertow,
B.P.T Motorsport are selling the factory Camshaft Synchroniser's for a ridiculous price of $482, nevertheless there are quite a few on the market now. But I will try the oil treatment first, this will at least be a good indication it's the Camshaft Synchroniser, if the problem subsides temporarily.
Regards
Old 30-01-2024, 03:15 PM   #16
raised by monkeys
raised by monkeys's Avatar
I ordered mine from the US years ago, delivery for under $130 i reckon
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2024, 05:15 PM   #17
fordomatic
fordomatic's Avatar
They are still cheap, I got one recently from my parts guy for $145.
Proud owner of the ugliest Ford ever made
fordomatic is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2024, 12:55 AM   #18
PG2
#neuteredlyfe
PG2's Avatar
Sorry Edxr6 that I lead you up the wrong path.
I should have said to check it first.
Old 31-01-2024, 03:01 PM   #19
Edxr6
All good PG2,
It would have needed to be changed in the near future I guess with 180,000klm on the clock. Most of the engine components are all factory, except the valve springs and retainers. They were only changed out because I had the common problem of a cracked valve spring and went with the heavy duty Crow set up.
I am guessing all the mechanic moving parts on these motors are coming to age and soon require replacing, it's all part of ongoing maintenance.
