Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 12-09-2023, 06:09 AM   #1591
JKL
Default Re: Genuine Ford Parts
Hi, are panels still available from ford for the fgx, chasing drivers side front guard???
Thanks in advance
JKL is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2023, 09:14 AM   #1592
GTLEGEND
Thanks in advance
Yes limited supply, $320 plus freight.
Old 12-09-2023, 07:34 PM   #1593
cat007
Hi mate.
A bit of a long shot - but - FGX XR8 bonnet. Is that something that is still available and dare I ask the price?
Cheers!
Hunt
cat007 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2023, 08:08 PM   #1594
GTLEGEND
Originally Posted by cat007 View Post
Hi mate.
Cheers!
Hunt
Hey mate,
Although still available, they are a currently a restricted part meaning we may or may not get. They are around the $1500 mark plus freight on top if need be.
GT
Old 12-09-2023, 10:20 PM   #1595
mad2
Regular...with metamusal
Hi Legend. another query but regarding the AU, BA glovebox lock. did the two models use the same locking mechanism?. part number for the AU i believe is ER F06004 A6 & i have no idea re the BA. going by photo's they look very similar.
Thanks
mad2 is online now   Reply With Quote Multi-Quote with this Post
Old 12-09-2023, 10:29 PM   #1596
GTLEGEND
Thanks
In AU Series there were 4 different glovebox latches, basically only because of the different trim colors but the mechanism is the same. Not sure off the top of my head if the mechanism separated from the handle part. They are:
AU2F06004A1D: Dark Graphite
ERF06004A1: Medium Graphite
ERF06004A6: Warm Charcoal
ERF06004A16: Light Graphite
In BA/F Series there are four part numbers:
BAF06004A1: Warm Charcoal with lock and keys.
BAF06004A6M: Medium Stone with lock & keys.
BAFF06004A1: Warm Charcoal less lock & keys.
BAFF06004A6: Medium Stone less lock & keys.
Hope that answers your question.
GT
Old 12-09-2023, 11:09 PM   #1597
mad2
GT
thanks. i'll take that as meaning the AU/BA lock mechanism is the same. which answers my question
Old 17-09-2023, 02:05 PM   #1598
mchaggis
mchaggis's Avatar
Hi GTLegend,
I'm chasing a set of four (two per side) of the clips that the lower door sill/trims screw into. B series Falcon. These are the clips that press into the metal of the body and the trim piece sits over the top, there are two screws and one push in retainer. The trim piece is garnished with a small aluminum plate that says Ford, or in my case FPV.
I'm not talking about the lower weather seal/strip that sits atop the skirt, I already have those clips.
Hopefully that's enough to go on?
The Current Fleet:
2018 Kia Sportage GTLine
2014 FG-X G6E T
2012 FG-II GTP #288
2002 AU-III XR8
(1977 TE Cortina, 2001 AUII XR6, 2004 BAI XR8 Ute, 2005 BAII Typhoon, 2008 FG F6, 2015 FG-X XR6 Ute, 2006 SY Territory Turbo Ghia...it just used too much fuel)
mchaggis is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2023, 11:57 PM   #1599
GTLEGEND
Originally Posted by mchaggis View Post
Hi GTLegend,
Have a look at the image below and see if you can ID the clips you are referring to ands we can go from there.
Old 18-09-2023, 10:05 PM   #1600
mchaggis
mchaggis's Avatar
Attachment 106714
Hi, it's none of those parts. If you follow the link, it the clips that the screws drive into. These things are held in by two screws and one push clip. I need the lugs for the screws.
https://www.ebay.com.au/itm/17588496...mis&media=COPY
The Current Fleet:
2014 FG-X G6E T
2012 FG-II GTP #288
2002 AU-III XR8
Old 18-09-2023, 10:26 PM   #1601
GTLEGEND
Hi mate,
Sorry miss read the description, should be HC1 in the image below? How many do you need? Can get for $5 each plus postage if that's exactly what you're chasing.
Old 21-09-2023, 08:15 PM   #1602
mchaggis
mchaggis's Avatar
Hi mate,
Attachment 106719
Yeah that's them, I'll take 4 thanks.
The Current Fleet:
2014 FG-X G6E T
2012 FG-II GTP #288
2002 AU-III XR8
Old 23-09-2023, 07:45 PM   #1603
mchaggis
mchaggis's Avatar
Ol'mate?
The Current Fleet:
2014 FG-X G6E T
2012 FG-II GTP #288
2002 AU-III XR8
Old 24-09-2023, 03:01 AM   #1604
GTLEGEND
Send me a PM and we can organize..
Old 24-09-2023, 11:47 AM   #1605
KRISL
KRISL's Avatar
hi mate,
any chance of confirming these two part numbers for these three FG IRS bushes
workshop manual mucked up the numbering for the description on one( i think)
Current 2009 FG GTP
Sold
2003 boss 260 xr8 daily driver
1991 eb1 xr8 once a year driver, factory cassette player
KRISL is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2023, 01:11 PM   #1606
GTLEGEND
Originally Posted by KRISL View Post
hi mate,
Bush circled 6 is BA5B639A.
Bush circled 3 is 8R2Z5B719AB
Bush circled 4 is SX5B639B
Old 24-09-2023, 02:10 PM   #1607
KRISL
KRISL's Avatar
hmm bit strange you say the top outer, and bottom front outer have a different number.
as seen here, the ford reference number for these two are 5A659 so should be the same part?
cheers
Current 2009 FG GTP
Sold
Old 24-09-2023, 03:26 PM   #1608
GTLEGEND
cheers
In the pics you provided 1 ,3 & 7 outer bushes are the same 8R2Z5B719AB, how ever you had circled one inner 6 and one inner 4 which are different. You only circled 6, 3 and 4.
I only provided the part numbers you had circled, nothing else and you only have one outer bush 3 circled the other two are inners.
Old 26-09-2023, 08:45 PM   #1609
GTLEGEND
For CS123.
BA BF Front Springs
FG Front Springs
BA BF Rear Springs
FG Rear Springs
Old 28-09-2023, 12:43 PM   #1610
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Genuine Ford Parts
G'day GTLEGEND.
Can you please confirm if part number BG 2B663 A is suitable for 06/2008 FG?
If so, how much for a pair posted to NT 0830.
Thanks.
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2023, 01:12 PM   #1611
GTLEGEND
Originally Posted by PHANTMXR6 View Post
G'day GTLEGEND.
Thanks.
Hi Mate,
That is the correct part number for wheel bearing hub on a 6/2008 FG how ever the part number has been superseded to J2MZ1104B.
$320 for the pair including postage to NT.
GT
Old 02-10-2023, 09:20 AM   #1612
E.T.
Hi GTLEGEND,
What are these clips called and, is there a suitable replacement? From the skirt on the front end of the tub, XR6.
Cheers!
E.T. is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2023, 02:07 PM   #1613
GTLEGEND
Originally Posted by E.T. View Post
Hi GTLEGEND,
Cheers!
To be able to confirm I need to know what model ute.
Old 03-10-2023, 09:33 AM   #1614
E.T.
‘08 BF MkII XR6 cheers
Sent from my iPhone using Tapatalk
Old 03-10-2023, 08:30 PM   #1615
GTLEGEND
Described as "Clip - Push On" can get for you at $6 each plus postage.
Cheers,
GT
Old 04-10-2023, 10:31 AM   #1616
E.T.
Cheers,
GT
Thanks GT, I ended up finding three of them at the wreckers!
Old 07-10-2023, 09:22 PM   #1617
matty88
Any chance of a NOS boot garnish seal for a Series 2/3 AU Fairmont sedan?
matty88 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2023, 03:03 PM   #1618
Dingo
Ford T3 Partsologist
Dingo's Avatar
G’day GT can you please get these for me
1 x F5TZ-6734-BA Sump Plug Washer
1 x 91AG-17A612-BA Connector for washer jet
2 x 7S71-17666-AD Washer Jet
Suits MA Mondeo Zetec 2008
also can you see if Ford has a Tool to suit 1S7G-6A832-BB Oil Filter Cover
Thanx Dingo
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2023, 09:42 PM   #1619
fordomatic
fordomatic's Avatar
G'day GT, chasing one of these plastic pillar trims to suit a ute, passenger side AU, BA, BF
Cheers mate,
Fordo
Proud owner of the ugliest Ford ever made
fordomatic is online now   Reply With Quote Multi-Quote with this Post
Old 08-10-2023, 10:34 PM   #1620
GTLEGEND
If you mean the mould above the number plate that holds the number plate lens/lights, then unfortunately no longer available.
