25-09-2024, 06:43 PM | #181 | ||
I've never quite understood why the minimum size for a modern 4 cylinder, seems to be around 1.2L?
With the latest tread towards smaller engines with turbos, there's a lot of manufacturers coming out with 3-cylinder jobbies. It seems to me that's a big sacrifice, considering the loss of balance. Don't get me wrong, most of them are doing a great job to overcome the inherent problems. I'm just not sure I understand the need? In something like a Puma, it's not a question of space. And I'm not sure the cost savings would be worth it. It would be lighter, but it seems like there's a technological resistance. Perhaps beyond a certain point, making a 4-cyliner smaller just doesn't deliver the fuel savings??
I can hear the Hippies crying from here. |
25-09-2024, 08:38 PM | #182 | |||
Think of it like this - - Smaller block, less material - Smaller head, less material - Smaller crank, less material - Smaller oil pan, less material - Smaller valve cover, less material - Smaller intake and exhaust manifolds, less material - One less piston, rod and associated hardware - Four less valves, valve springs, followers. - Smaller gaskets, seals ect. Then, assembling all of that is quicker on the line. Overall, the cost per engine is lower, which adds up over the course of the engine's lifespan. We are talking hundreds of millions of dollars in savings here. In theory, servicing costs will be lower for the customer as well. So, I guess the question becomes, why carry around that extra cylinder when its absence for the most part wont be noticed by the customer. For the record, I don't want to own a 3-cylinder vehicle, but I don't hate the format either because the Ford versions are really nice to drive and sound good too.
25-09-2024, 08:44 PM | #183 | ||
I got no problem with the three cylinder turbo job, would rather see naturally aspirated 4 cylinder engines discontinued and replaced with turbo 3 cylinder engines.
You can make the same amount of torque but bring it in from 1500-2000 RPM on the turbo 3, instead of at 4000 RPM on a naturally aspirated 4 cylinder engine. Makes for a way nicer car to live with on a daily basis with the turbo 3. With what the Fiesta ST is like to drive with its peak torque coming in from 1500 RPM and maintaining it all the way out to 5000 RPM, makes for a very nice manual car to drive. |
25-09-2024, 09:00 PM | #184 | |||
25-09-2024, 09:02 PM | #185 | ||
I have had two different Vw service guys tell me that the Vw 1 litre three cyl petrol ( which comes in at least three times of ke/torque) is the best motor Vw make.
The top tune is 85 kw and 200 nm torque at 2000 rpm Whereas in my Puma The Ford three cyl is 92 kw and 170 nm torque at 1400 or 1500 rpm I haven’t driven the 85 kw tune But my wife’s Polo is 70 kw and 175nm and is really laggy from take off while the Puma leaps out of the blocks Maybe auto gearbox issues |
25-09-2024, 09:03 PM | #186 | ||
Three tunes of kw/torque
25-09-2024, 09:13 PM | #187 | |||
That 92KW/170NM is the same figures as the WZ Fiesta Sport, same engine I guess |
25-09-2024, 09:17 PM | #188 | ||
Yeah they are nice
Although hills dull the Puma the extra suv pork ( body weight) slows it up |
25-09-2024, 09:21 PM | #189 | ||
25-09-2024, 10:23 PM | #190 | ||||
That said, I wonder if part of the cost saving is utilising existing head designs and technology, rather than designing an entirely new engine of that size. Quote:
If you want to turbo-charge a 1.0L engine, why not do it to a 1.0L 4-cylinder.
Yesterday, 12:39 AM | #191 | |||
My Fiesta St standard had a throbby deep lower bass sound, but revving it was blah- there was no hard brassy edge or mechanical rasp and rattle of the good type like a good sporty vtec wrung out. I then put on an alloy Mountune intake induction elbow to replace the plastic OEM intake elbow that had a restriction. What I immediately noticed was the engine sounds a bit more brassy edged even driven normally, has lost some of the standard engine muddy low sound, and when I rev it out it gets that mechanical rasping rattle edge sound that is great. With a Dreamscience stage 1 99+ tune with a mix of e85 running at some 240 odd hp with 385 nm, the engine is a lot more brassy mechanical rasping edged which sounds great revved, which I just love. It certainly now is not a quiet engine, and I am talking induction sound only when revved. I think plastic is a great sound deadener on critical "trumpet " sound elements on an engine, but alloy metals on these "trumpet" sound components transmits the higher brassy edge of sound so much better.
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender Last edited by asagaai; Yesterday at 12:51 AM. |
Yesterday, 12:56 AM | #192 | |||
Also, a 3 cylinder often is designed with stroke etc and tuned to produce more torque but less power than a similar sized 4 cylinder engine. So it feels like a big lazy engine because of that characteristic.
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender Last edited by asagaai; Yesterday at 01:20 AM. |
Yesterday, 09:43 PM | #193 | |||
(Not a criticism, just my observations)
Today, 01:04 AM | #194 | |||
The ST needs a good stage 1 tune like the Dreamscience tune, foam filter and alloy mountune throttle body. It smooths out the initial boost curve and extends the torque and power very very nicely into the upper revs. It is now a totally different drive in terms of power delivery and sound. With the standard ST I got bored with the engine, with the mods now, if the temp is below 18 degrees odd it is a blast, and in the wet if I push it in 3rd it is actually quite scary WOT.
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender |
Today, 09:34 AM | #195 | |||
