22-09-2024, 03:33 PM | #1 | ||
Hi folks,
Is anyone aware of a stripped screw/bolt removal service in Orange, NSW. I HAVE A 2mm Allan grub screw in a sewing machine that has been munted. I’ve tried jamming a torx driver in, and an easy out. The screw is only 4mm long, so getting purchase is difficult. The other screw on the shaft was severely overtightened, but I was able to get it out in one piece using Allan key and scanner. I have used penetrating oil and freeze spray on the damaged one , without luck. Cheers Steve
Steve Current rides 2012 Mondeo Titanium wagon (TDCI) Moondust silver 2016 Focus Trend, 1.5ecoboost, 6sp manual. Frozen white Previous 2004 Berlina Wagon (LS1) Vespers Blue 1995 Camry 2.2, white 1971 Ford Fairmont wagon 302w, C4 Polar white 1971 TC Cortina, 2L 4sp, Ermine white |
22-09-2024, 04:23 PM | #2 | ||
No; but what about:
Hidden Talent Orange Sewing Machine Repairs & Service Shop 1 153/157 Peisley St, Orange NSW 2800 (02) 6362 0011 Or drill it out with a reverse (left hand) drill bit (e.g. https://www.amazon.com.au/YUENTOEN-E...s%2C301&sr=8-6) and replace it perhaps.
regards Blue |
22-09-2024, 04:29 PM | #3 | |||
regards Blue |
22-09-2024, 05:23 PM | #4 | ||
3 users like this post: |
22-09-2024, 05:26 PM | #5 | |||
Thanks,
We are an authorised service agent. This is a case of a knucklehead butchering something. Quote:
22-09-2024, 05:28 PM | #6 | ||
Has anyone had experience with Kingchrome quick-outs?
Maybe on a pedestal drill, they could do the job?
22-09-2024, 05:36 PM | #7 | ||
I work on a lot of old shitty cars, and use these things:
https://www.bunnings.com.au/irwin-3-...76224_p0621022 Never failed yet. Not sure they go down to 2mm. |
22-09-2024, 05:37 PM | #8 | |||
Aldi have similar items on special buys at the moment too. Same as these: https://www.aldi.co.uk/workzone-dama...96188205481300
regards Blue |
22-09-2024, 05:41 PM | #9 | ||
regards Blue |
22-09-2024, 05:45 PM | #10 | ||
2mm - if that’s the major diameter - is so small, I’d think you need to make a drilling jig. Hole is blind?
22-09-2024, 05:57 PM | #11 | ||
Depending on how munted, munted actually is,
a 3/32" imperial hex key is a little larger then metric 2mm forced in, it might be enough... |
22-09-2024, 06:12 PM | #12 | |||
I get the feeling that experience counts in a situation like this…hence my cry for help.
23-09-2024, 08:24 PM | #13 | |||
Excessive Fuel Ingestion
A gentle bit of heating may help if possible. Ed
Recommended Forum Traders: RSGerry, trimmaster, 51OAU, EB-92, adxr8, my67xr, RG, ZA-289, kruptor, gassa, Felony, RNXR, Rhino 351, Anchor, Smoke Pursuit, Mr. FPV (through E-Bay), |
24-09-2024, 02:33 AM | #14 | ||
Heating it gently can also help loosen things up.
29-09-2024, 09:10 PM | #15 | ||
whats the end result
30-09-2024, 06:19 AM | #16 | ||
Bad result!
After heat and freeze spray, the easy out I used chewed the grub screw out, tith the bottom of it holding fast. The fitting has been ground off and replaced. I’m sure a machinist could have drilled it out, re-tapped and installed a larger grub screw. But at what cost? And the danger of damaging the shaft.
