25-09-2006, 07:40 AM | #1 | ||
With da Warlords
Well there we are.
Friday night, I decided spur of the moment style I was going to change my cam. Later that night I had my spare xr6 engine apart with the cam in my hands : . Saturday morning I chucked her in my car. I have to say when I first swapped them over I was dissapointed at how it ran. It actually seemed slower, but the computer has not realised what I have done and so it would seem that theres a lot more power to come. As I've been drving over the weekend it has started to get a little more responsive & better idle as the computer adjusts. I just cant wait for the flash tuner to turn up this week, that should really open her up. All up the job took me about 8 hours, and for anyone that hasn't done it before, believe me it's not that big a job to do. I found the worst part was removing the power steering pump and putting it back on so that I could get to the chain tensioner. Anyway thats was my weekend, a bit dissapointing but seems to be improving now with every km :
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
25-09-2006, 08:16 AM | #2 | ||
TL40 Wagon?
XR6 Cam alone won't do much. The XR6 needed the head cam and ecu to get the extra power. You'll be waiting a long time for the computer to adjust to give you more power to so give up on that idea and get the flash tuner for sure. The ecu won't be doing any adjusting just cause you swapped the cam. It will only be going through its idle train and trims if you disconnected the battery. Now a flash tuner will get the best from this set up.
Good luck and let us know how it all goes with the tune |
25-09-2006, 06:59 PM | #3 | ||
good on you mate.. i also got a different cam on the weekend butit took me an hour to do my cam, not 8
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
26-09-2006, 07:08 AM | #4 | |||
With da Warlords
My computer is only now realising that air fuel ratio should be 14:7, used half a tank of ultimate in 100km.
26-09-2006, 05:54 PM | #5 | |||
Boost Addict
14:7? 14:1 is about right for a factory tune, and yes it takes the ecu a little while to adjust for a new high lift cam
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
26-09-2006, 07:05 PM | #6 | |||
