Old 05-12-2007, 01:59 PM   #1
kirdeev
Default Parking Lamps Problem
Hello,
I would appreciate any advice how to fix my problem. I have Ford Focus SE 2000 (no fog lights). A couple of days ago the parking lamps and instrument cluster lighting went out suddenly when I pressed remote luggage compartment release button. Side lights (left, right), brake lamps, back-up lamps, and hazard flasher are working fine. When I press brake pedal, the instrument cluster lights up normally.
First, I changed brake lamps because I thought they burned down. It happened before. Then I checked fuses - they looked fine. Then I replaced headlight switch, but it didn't help. I bought a used one. Maybe I need to get a new switch.
Thank you for your recommendations,
Dmitri
kirdeev is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2007, 10:51 AM   #2
BlackLS
yum
Have you tried to change the light relay?
2005 LS Focus LX
250,000kms.
Old 07-12-2007, 01:22 PM   #3
kirdeev
People say that a ground connection became faulty. Can somebody advise where I can find ground connections in my car?
Thank you,
Dmitri
Old 07-12-2007, 01:23 PM   #4
kirdeev
I didn't change the light relay.
Old 08-12-2007, 03:58 AM   #5
BlackLS
yum
Try testing first the fuses in question using a multimeter. Sometimes they can get a hairline crack thats not immediatly visible.
Go onto google and check out "car electrical problem diagnostic"
2005 LS Focus LX
250,000kms.
