[ 5L ]
i am currantly about to run my wiring so i can hook my new sub and amps but am confused as to where to run the 4 gauge wire, in my eb i ran it down the left hand side of the engine bay and down the gaurd then into the cabin.
i have tried to do this but it fouls on the door. i know most run it through there clutch cable hole, but mine is manual so thats no good. any help would be appreciated. cheers.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
Formerly MR BAXR6t
Hey
i had similar problem with runnin my power lead through the fire wall. I ran it though a hole behind the accelerator, there was a hole that i squeezed it through. Hope this helps in some way Frank
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
I don't know if it will fit, but there is a small small hole with a rubber plug in it, near where the steering wheel arm exits the firewall, inside the engine bay.
EDIT: Just beaten to it. |
[ 5L ]
ok cheers ill check it out
[ 5L ]
nope i dont know if im blind, but i cant see it.
is it possible to get photos? or an alternate option
Formerly MR BAXR6t
yea ill take a pic
Formerly MR BAXR6t
Sorry not the best pic but u sorta get the idea
i ran mine through the hole where the bonnet relese cable goes, handy because it goes to the top of the wheel arch where i attached my fuse then runs to the battery.
This is the area you have to look at. What you're looking for is a small rubber plug in a small cylinder. It goes through the firewall and all you do is push it through a slit in the foam in the inside of your car.
The images a from a forums members car. I hope you don't mind. |
[ 5L ]
i might downgrade my wire, mr auxr8 that wire looks to be 8 gauge, my wire is thicker than that, i found that hole but there is no way i could get mine through there. same with the bonnet release cable there is no way i can get it through the grommet.
jmo those pics you have shows the clutch cable hole i cant use that as my car is manual.
Sorry. My bad.
#12 | ||
Young !@#$ Head
Let me know how you go with this. I have the fatter wire you are talking about AUXR8220 going through my clutch cable hole (only just fits through the whole) although my manual goes in mine in 4 weeks when my clutch arrives so i'll need a new spot for the stereo cable
www.aufalcon.com.au/blackauxr8 AU3 220 XR8 CUSTOM PEARL PAINT LOWERED THEN LOWERED EVEN MORE ADVANTI 20's K&N PORTED MANIFOLDS TWIN 2 1/2 into 3 inch PIPES 244rwhp NOW WITH T5 5 SPEED COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL SUZUKI GSX-R 750 BLACK 2007 MODEL CARBON FIBRE YOSHI PIPE |
Formerly MR BAXR6t
Yea that was the only hole i could find that fitted And it JUST fitted. There was no need for the thicker wire. Im runnin 2 P2 15" Rockfords and Rockford amp and runs perfectly.
Good luck mate Frank
#14 | ||
Young !@#$ Head
Nice set up. They dont sell rockford much up here anymore. Im running 1 HX2 15'' rockford with 800 watts rms going into it. Have done for 2 years now. Never missed a beat. I want a rockford amp but they dont sell them anywhere up here now.
#15 | ||
OzFalcon.com.au
best place to buy them is off the internet in the states, much cheaper, its where i get all my audiobahn gear from
is there a reason why u dont want drill a hole through your firewall? i run 0 gauge and have to do it, jsut drill a hole and go to a wreckers and take a grommet thats the correct size and put that into your new hole |
#16 | ||
[ 5L ]
didnt really want to drill holes but might have to, ive got the system all hooked up now. for the time being i worked out a way how to run the power wire. but its dodgy as lol. ill fix it up tomorrow or saturday.
i did what i did on my eb, but ran the power cable through the rear door. it all works fine, doesnt rub or anything but just looks bad.
#17 | ||
Young !@#$ Head
that could be what has to be done in the end. I'll find out once the manuals in and i've gota run the cables again.
#18 | ||
Fordless
Mine's a manual running 4 gauge cable & Stav got it through without any cutting etc.
#19 | ||
OzFalcon.com.au
well dont hold out on us, how did u do it lol, otherwise that post was pointless
#20 | ||
[ 5L ]
lol mrjucy how did you and stav get it through
#21 | ||
Fordless
I'll have a look under the bonnet & see if I can work out where it goes through. I know it's on the drivers side but as I said Stav put it through so I'd suggest if you ask him nicely he might let you know how he did it assuming it's not a trade secret. :P
#22 | ||
Why not run two 8 gauge wires through the smaller holes? Would the total voltage/power they supply combined be the same as a single 4 gauge?
#23 | ||
[ 5L ]
lol this is the set up i did so i could have them working for the time being, until i find a suitable way to run it.
![]() as you can see here the wire runs up the engine bay. ![]() lol this is where it gets dodgy, wire runs down the guard to the top of the side skirt, runs along the side skirt. then gaffa taped up to stop it from getting caughts. (for more experiences with gaffa tape, cable ties, and pop rivets see the e-series section lol.) ![]() it wouldnt clear the door seal on the front door so i ran it through the rear door. it doesnt rub and where, i barely notice it there. very rare i have rear passengers. lol im coming up with excuses now, but thats probably because it will more than likely stay there for a while
#24 | ||
lpg = big boom!
you realize there is a cable track that runs the entire length of the car?
BF Futura Dedicated E-GAS w/Ghia bling Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM ![]() |
#25 | ||
The Monty
hahah i like ur style Auxr220.. home made jobs that work well until fixed... But BeStRaFe is correct im pretty sure i seen some others mention it as well.
#26 | |||
All Bran = Regular Member
#27 | ||
[ 5L ]
yeah cable track is nice and all, not worries about that, its the firewall that is a pain.
and yes homemade dodgy jobs are the best lol
#28 | ||
lpg = big boom!
i think your best idea is to drill the firewall and install your own factory style grommet.
#29 | ||
lpg = big boom!
or is there room where the computer wiring goes into the car
bottom right of firewall if you are infront of car
#30 | |||
Flying high...
cheerz
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel, 3" mandrel intake, K&N pod in the box, Polished Rocker Cover. |
