20-03-2008, 01:21 PM | #1 | ||
too many fords
Just read through nthe forums about this and iuts seems it could be coil packs? anybody shed some light on this.
Its only just started doing this, car has 160k on clock has new plugs. I dont want to change leads yet as they are bloody expensive. |
20-03-2008, 01:34 PM | #2 | ||
$62 for some Eagle 8.0mm spiral wound leads at Carbitz is what I bought.. Hardly expensive.
20-03-2008, 01:42 PM | #3 | ||
too many fords
I just got qouted $172 for 9mm top guns. Its not just that they are expensive its replacing i dont need to. Its an XR8 not a six.
Last edited by old fordnut; 20-03-2008 at 01:43 PM. Reason: forgot to add something |
20-03-2008, 03:47 PM | #4 | ||
Has the fuel filter been changed recently as I had a rough idle a while back and it was just a blocked fuel filter
20-03-2008, 10:10 PM | #5 | ||
CRE.87V
mine is doing the same...fuel filter was done 8k ago....could it be pump...??? mine also takes a while to turn over when its warm...starts perfect wen its cold
