Old 18-04-2008, 10:43 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Solenoids, how do they work?
Hi all
after a bit of info on how solenoids work, specifically one that opens the fuel filler door on sedans. I have one here and Ive just about got it figured out to work on the ute, I just need a bit of info on how they are powered etc. It has 2 connectors (just prongs) so I am assuming its just a matter of getting power to it, then connecting it up to the loom in the dash so the button works? Is this correct? I have the button on the dash in there now and it does have a loom to plug into, but I havent traced it yet to see how far it goes.
2024 F150 XLT
Old 18-04-2008, 11:00 PM   #2
tufLTD
tufLTD
tufLTD's Avatar
Solenoids are the electro-magnetic device usually used to push or pull a plunger. Power is applied to create a magnetic field that moves a metal plunger in or out. All they need to operate is a positive & negative wire. Positive current is supplied through a simple on-off switch and the circuit is completed with an earth wire.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2008, 11:00 PM   #3
b2tf
b2tf's Avatar
Sounds easy enough. I think the hardest part will be wiring the switch in the dash so it works correctly.
2024 F150 XLT
Old 18-04-2008, 11:05 PM   #4
tufLTD
tufLTD
tufLTD's Avatar
It would be best to use a positive power supply that is always on (direct battery current), regardless of igniton on or off. That way you can open your filler cap without having to use your key or turn ignition on. You should be able to locate an "always on" power supply from the fusebox with a simple circuit tester.
Old 18-04-2008, 11:11 PM   #5
zetec
Zoom Zoom
zetec's Avatar
I wouldn't advise that... battery wouldn't last too long. I think the car turns them on when the doors are unlocked.
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2008, 11:16 PM   #6
tufLTD
tufLTD
tufLTD's Avatar
Why wouldn't the battery last long???
There is no current draw until you operate the switch.
Old 19-04-2008, 01:42 AM   #7
zetec
Zoom Zoom
zetec's Avatar
Yeah good point. It's late on a Friday. Brain's off!
2012 Mazda3 MPS
Old 19-04-2008, 08:51 AM   #8
Tech Trainer
Are you sure about that?
Tech Trainer's Avatar
However I would advise a fuse in the circuit, just in case the power wire rubs through and develops a short circuit.
When I grow up, I want to be half as good as you THINK you are.
Tech Trainer is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2008, 05:32 PM   #9
teabags2
Bob
Solenoids are built to provide high levels of mechanical force for a short time. That is they will oveheat and burn out if you keep them powered up for more than a quick click to release the latch. The switch needs to be monentary so you don't accidentaly leave it turned on and burn the solenoid out.
Bob
teabags2 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2008, 08:21 PM   #10
chief
FTF Club Moderator
chief's Avatar
Bob
A relay will solve this problem.
Albert Einstein:
Fords in the Park 2010
Old 19-04-2008, 08:47 PM   #11
b2tf
b2tf's Avatar
Ok next question, on a ute, whereabouts does the main loom run to its furthest point on the back of the car? I.e, where does it stop?
2024 F150 XLT
Old 19-04-2008, 09:20 PM   #12
bodes-sh
i would probably say fuel pump, that is behind the cab anyway and almost to where you will want the wiring for a fuel door release...that and the tail lights
Old 19-04-2008, 10:26 PM   #13
tufLTD
tufLTD
tufLTD's Avatar
I would guess that the rear-most point which provides constant battery supply would be to door courtesy light switches. It would be easy to branch into this wire & run it to the fuel cap solenoid.
Old 19-04-2008, 10:40 PM   #14
b2tf
b2tf's Avatar
The main loom from what I can see already has wires to power the solenoid. It has a plug thats in the dash where the buttons attach, I just need to follow the loom to find these wires.
2024 F150 XLT
